ric Posted December 7, 2011 Share Posted December 7, 2011 Hey guys, I'm tried to search for this and can't really find a definate answer. If I have an uprev on my 350, do i lose the ability to use the cruise control? Thanks, Quote Link to comment Share on other sites More sharing options...
Clarkie Posted December 7, 2011 Share Posted December 7, 2011 No, you will retain cruise control Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 7, 2011 Share Posted December 7, 2011 No, you will retain cruise control No quite - in certain setups you will lose it. IIRC its when you have the true 1:1 throttle map you lose the cruise as it cant handle the 1:1 throttle programming. If you have the "sharpened" throttle map which isnt 1:1 direct mapping, you will retain it. Not sure I know anyone that has taken the 1:1 throttle map yet, I think most will keep cruise instead. 1:1 map will be for track cars I guess. Quote Link to comment Share on other sites More sharing options...
ric Posted December 7, 2011 Author Share Posted December 7, 2011 Ahh OK, so under normal circumstances I'll keep my cruise control? Cool What is 1:1 Throttle map? Thanks, Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 7, 2011 Share Posted December 7, 2011 What is 1:1 Throttle map? It means that for every 1% you move the throttle pedal, the ECU will move the throttle plate open 1%. So at half way throttle pedal travel, the throttle will be open 50%. Foot flat to the floor, the throttle will be open 100%. As standard the car is fly-by-wire which means the movement from the throttle pedal is interpreted by the ECU and the throttle plate moved as much or as little as the ECU deems required. As such it doesnt move it 1:1 based on the pedals, it bases it on other paramters such as engine load, engine revs and the gear you are in too I think. So UpRev can play with this map or transalation from pedal position to throttle opening, with the *holy grail* being 1:1. I'm not sure how much it can tweak it before he breaks the cruise control, but there is some movement. Mark from Abbey will be able to explain more Thats my understanding, altough things may have changed by now. Quote Link to comment Share on other sites More sharing options...
ric Posted December 7, 2011 Author Share Posted December 7, 2011 Ahh OK, that makes sense. So when people talk about one of the plus points of an uprev being that the lower gears "aren't limited anymore", is this what they refer to? Thanks, Quote Link to comment Share on other sites More sharing options...
ianphampton Posted December 8, 2011 Share Posted December 8, 2011 Lower Gears being limited refers to the Nissan default where the throttle will only give: 55% max power in 1st 65% max in 2nd and 75% max in 3rd So your pedal at 100% to the floor will still only give 55% power in 1st Apparently Nissan limited the power through the lower gears to reduce the wheelspin risk. When you have an Uprev these limits are removed, so you can get full power. I tend not to go nuts in 1st, but the extra power in 2nd is noticeable and you'll come off a roundabout much more sharply and as you straighten up and then give her the beans she just loves kicking you in the lumbar region and lifting her nose . . . . The full power in 3rd is even more useful, and I think it's safer, too, as it improves overtaking so you're in the other lane for a shorter time Of course, the TCS will still kick in to stop you spinning wheels (unless you turn it off) I do turn mine off in fine weather and it's surprising how much grip you have, so in the dry it's good fun. This time of year, though, I leave the TCS alone (or you'll come off that roundabout sideways or backwards!) Quote Link to comment Share on other sites More sharing options...
Southernspeed Posted December 8, 2011 Share Posted December 8, 2011 Lower Gears being limited refers to the Nissan default where the throttle will only give: 55% max power in 1st 65% max in 2nd and 75% max in 3rd So your pedal at 100% to the floor will still only give 55% power in 1st Apparently Nissan limited the power through the lower gears to reduce the wheelspin risk. When you have an Uprev these limits are removed, so you can get full power. I tend not to go nuts in 1st, but the extra power in 2nd is noticeable and you'll come off a roundabout much more sharply and as you straighten up and then give her the beans she just loves kicking you in the lumbar region and lifting her nose . . . . The full power in 3rd is even more useful, and I think it's safer, too, as it improves overtaking so you're in the other lane for a shorter time Of course, the TCS will still kick in to stop you spinning wheels (unless you turn it off) I do turn mine off in fine weather and it's surprising how much grip you have, so in the dry it's good fun. This time of year, though, I leave the TCS alone (or you'll come off that roundabout sideways or backwards!) I believe Mark has now proved this incorrect and that it is as described in a recent post that the throttle butterfly doesn't follow the pedal per % but it does make 100% open. Kind of like opening the throttle with a bungee chord! Quote Link to comment Share on other sites More sharing options...
ric Posted December 8, 2011 Author Share Posted December 8, 2011 Lower Gears being limited refers to the Nissan default where the throttle will only give: 55% max power in 1st 65% max in 2nd and 75% max in 3rd So your pedal at 100% to the floor will still only give 55% power in 1st Apparently Nissan limited the power through the lower gears to reduce the wheelspin risk. When you have an Uprev these limits are removed, so you can get full power. I tend not to go nuts in 1st, but the extra power in 2nd is noticeable and you'll come off a roundabout much more sharply and as you straighten up and then give her the beans she just loves kicking you in the lumbar region and lifting her nose . . . . The full power in 3rd is even more useful, and I think it's safer, too, as it improves overtaking so you're in the other lane for a shorter time Of course, the TCS will still kick in to stop you spinning wheels (unless you turn it off) I do turn mine off in fine weather and it's surprising how much grip you have, so in the dry it's good fun. This time of year, though, I leave the TCS alone (or you'll come off that roundabout sideways or backwards!) Thanks for the explanation. But how does this relate to the cruise control still being available? Thanks, Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 8, 2011 Share Posted December 8, 2011 Lower Gears being limited refers to the Nissan default where the throttle will only give: 55% max power in 1st 65% max in 2nd and 75% max in 3rd So your pedal at 100% to the floor will still only give 55% power in 1st Apparently Nissan limited the power through the lower gears to reduce the wheelspin risk. When you have an Uprev these limits are removed, so you can get full power. I tend not to go nuts in 1st, but the extra power in 2nd is noticeable and you'll come off a roundabout much more sharply and as you straighten up and then give her the beans she just loves kicking you in the lumbar region and lifting her nose . . . . The full power in 3rd is even more useful, and I think it's safer, too, as it improves overtaking so you're in the other lane for a shorter time Of course, the TCS will still kick in to stop you spinning wheels (unless you turn it off) I do turn mine off in fine weather and it's surprising how much grip you have, so in the dry it's good fun. This time of year, though, I leave the TCS alone (or you'll come off that roundabout sideways or backwards!) Thanks for the explanation. But how does this relate to the cruise control still being available? Thanks, Yes it does, if you didnt know what 1:1 ratio was your not going to need or want it. Chirs just confused you TBH . Yes you keep cruise. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 9, 2011 Share Posted December 9, 2011 What we should be saying is "speak to Abbey" as posts on the internet tend not to be the clearest way to explain things Quote Link to comment Share on other sites More sharing options...
rm cya Posted December 9, 2011 Share Posted December 9, 2011 Is an uprev remap the only way around this butterfly limiter? What's a rough price of an uprev? Quote Link to comment Share on other sites More sharing options...
