Topcat Posted December 6, 2011 Share Posted December 6, 2011 So last week I took my zed to be fitted for a new n-2 bumper and spoiler, pictures to follow when I get my camera working. Once picked up and driving home I realised the clock time had changed drastically so presumed the battery had died while standing for a week. Followed by a few days fine driving. Come Sunday morning with a heavy layer of ice, car started fine, drove home, off to bed. Woke up for work around 8 hours later and zed's dead. Voltometer is showing around 9. And when turning the key the engine won't crank. Headlights and all electrics working. does this sound likely to be a simple new battery job or maybe something more sinister? not tried jump starting as had a bad expensive experience in the past. Yet to hear back from the bodyshop to find out exactly the circumstances. Any help much appreciated, cheers tom. Also it's an 04 UK gt model. Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 6, 2011 Share Posted December 6, 2011 Sounds like the battery is ****ed. You could try charging it first though. But zeds can be a bit touchy if the battery is not 100%. Quote Link to comment Share on other sites More sharing options...
Topcat Posted December 6, 2011 Author Share Posted December 6, 2011 Should it not be at least trying to kick in to life with 9 volts? There is just a slight whurring noise when turning the key. Excuse my ignorance, I have very little knowledge about electrics. Quote Link to comment Share on other sites More sharing options...
Beavis Posted December 6, 2011 Share Posted December 6, 2011 Should it not be at least trying to kick in to life with 9 volts? No chance Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 6, 2011 Share Posted December 6, 2011 Check that the battery connections are tight Quote Link to comment Share on other sites More sharing options...
planetsurfer2 Posted December 6, 2011 Share Posted December 6, 2011 Battery. Batteries normally die after the first hard frost. Had the same happen to me last year Quote Link to comment Share on other sites More sharing options...
Topcat Posted December 6, 2011 Author Share Posted December 6, 2011 Ok thanks, I've checked over everything and all seems in place, probably the cold weather killed it off? Hopefully a new one will remedy it. From my research I hear the varta blue top is a decent one to go with? Quote Link to comment Share on other sites More sharing options...
sparky370z Posted December 6, 2011 Share Posted December 6, 2011 absolutely no chance with 9 volts. i would charge it up first, a very slow charge at 2 amps max over night. see how that goes. if the battery has been discharged, it takes AGES for it to become fully operational with just normal driving. the crank surge is very high on the battery needs to be in optimum capacity to turns the heavy lump over. plus being cold also does not help as all of the lubricants are colder and provide higher resistance on the moving parts than if it were warmer outside. Quote Link to comment Share on other sites More sharing options...
Dicky Posted December 6, 2011 Share Posted December 6, 2011 Should it not be at least trying to kick in to life with 9 volts? There is just a slight whurring noise when turning the key. Excuse my ignorance, I have very little knowledge about electrics. Not really. The 9v is measured with no current demand from the battery. If the batt is dead it will generally still show a decent voltage but if you take even 1A from it you would probably see the displayed voltage drop. I would have thought you should be able to take grat chunks of current from a good batt with not much drop in displayed voltage NEW BATTERY. Quote Link to comment Share on other sites More sharing options...
AK350Z Posted December 6, 2011 Share Posted December 6, 2011 Hopefully a new one will remedy it. From my research I hear the varta blue top is a decent one to go with? Varta are good batteries. I've got a silver one for my over sensitive Fiat. Quote Link to comment Share on other sites More sharing options...
leodspider Posted December 6, 2011 Share Posted December 6, 2011 get style and performance at the same time http://www.braillebattery.com/index.php ... s/b2015c/# Quote Link to comment Share on other sites More sharing options...
Topcat Posted December 6, 2011 Author Share Posted December 6, 2011 Varta coming tommorow. Is there any specifics I should know about when changing the battery on a 350? The alarm isn't going to lock me out or anything else similar? Thanks for the help guys, this really is a top forum Quote Link to comment Share on other sites More sharing options...
Ricey Posted December 6, 2011 Share Posted December 6, 2011 Deffo battery - same thing happened to ours last year.......don't even bother trying to recharge it - once its gone its fooked Quote Link to comment Share on other sites More sharing options...
ds2000 Posted December 7, 2011 Share Posted December 7, 2011 Yep, you'd probably start a moped with that Cold weather can suddenly bring battery issues to light! Quote Link to comment Share on other sites More sharing options...
