Removed Posted January 16, 2007 Share Posted January 16, 2007 when switching the A/C on, the radiator fan starts too. Doesn't matter whether I blow cold or hot air, the rad fan still goes?? Surely that's not normal, is it?? Quote Link to comment Share on other sites More sharing options...
stuey Posted January 16, 2007 Share Posted January 16, 2007 strange..................i wouldnt av thought so............ Quote Link to comment Share on other sites More sharing options...
lomoto Posted January 16, 2007 Share Posted January 16, 2007 at work now no car will check tonight if no one else gets back to you, seem to think this is normal though Quote Link to comment Share on other sites More sharing options...
Removed Posted January 16, 2007 Author Share Posted January 16, 2007 I seem to remember i read something somewhere about this, can't remember where? Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted January 16, 2007 Share Posted January 16, 2007 I would personally be surprised if they run all the time; I must admit I recall reading (not that I can find it either) that its the ECU which sends a signal to switch them on when required but that they are not auto-running with A/C. A few people posting up will satisfy this though ps its better for them to run that not Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 16, 2007 Share Posted January 16, 2007 not both on at the same time for me. Run with the air con on all the time. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted January 16, 2007 Share Posted January 16, 2007 not both on at the same time for me. Run with the air con on all the time. Same with mine - fan and A/C operate independently. Quote Link to comment Share on other sites More sharing options...
Removed Posted January 16, 2007 Author Share Posted January 16, 2007 to clarify it's the front radiator fan in the engine bay that seems to be starting with the A/C. I don't think it's normal, will have to go get it checked. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 16, 2007 Share Posted January 16, 2007 yep understood you Quote Link to comment Share on other sites More sharing options...
Removed Posted January 16, 2007 Author Share Posted January 16, 2007 booked it in for Thursday (well for confirmation of the fault, what a PITA!) including boot struts and clicking noise (might as well do the lot) Quote Link to comment Share on other sites More sharing options...
Removed Posted January 18, 2007 Author Share Posted January 18, 2007 apparently this is normal??? can you guys do me a favour and switch the aircon on, open the bonnet and check if the rad fan is blowing? Might be that it's normal but mine has just become slightly noisier? Getting clicking axle done under warranty and should also get uprated boot struts, fingers crossed Quote Link to comment Share on other sites More sharing options...
Removed Posted January 18, 2007 Author Share Posted January 18, 2007 the 350z-tech guys also confirmed it's normal.... I'd never noticed the noise before so my rad fan must b getting noisier then Quote Link to comment Share on other sites More sharing options...
stuey Posted January 18, 2007 Share Posted January 18, 2007 the 350z-tech guys also confirmed it's normal.... I'd never noticed the noise before so my rad fan must b getting noisier then i wonder why this is then Quote Link to comment Share on other sites More sharing options...
