Dicky Posted December 2, 2011 Share Posted December 2, 2011 Can you confirm that with the engine running, you turn the mirrors inboard using the armrest switch, then turn off the engine and remove the key, that the mirrors move out again? The reason I want to know is that Ive had problems with the installation (not cookies circuit) traced back to bad connections on the larger of the two white plugs on the armrest control unit. Im just wondering if this is normal or if Ive still got problems. Quote Link to comment Share on other sites More sharing options...
narcotix Posted December 3, 2011 Share Posted December 3, 2011 Alright mate, I've just tried the steps above on my zed and I get the same results. With the car ignition on, I moved the mirrors out.. Then just leave the mirror switch on the middle setting and then they work as normal.. Quote Link to comment Share on other sites More sharing options...
Dicky Posted December 3, 2011 Author Share Posted December 3, 2011 Alright mate, I've just tried the steps above on my zed and I get the same results. With the car ignition on, I moved the mirrors out.. Then just leave the mirror switch on the middle setting and then they work as normal.. Cheers young man , many thanks. I can relax now and enjoy! Quote Link to comment Share on other sites More sharing options...
narcotix Posted December 3, 2011 Share Posted December 3, 2011 No problem, Glad I could help ... Quote Link to comment Share on other sites More sharing options...
