ioneabee Posted November 30, 2011 Share Posted November 30, 2011 when using the onboard handsfree kit, I can hear perfectly clearly my caller, but appernetly I'm blanking out on their end all the time !! This is not a connection or signal issue (as far as I can tell) - as my phone is showing full signal (HTC) Does anyone else get this or know anything about it ? I'm about to log it as a warranty issue with the dealer Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 1, 2011 Share Posted December 1, 2011 Not had the same problem, in fact everyone says its crystal clear - and also when I've talked to Colin on his before he's been very clear too. Phones really arent very good at showing real time signal, so if you are moving it could very easily be the signal, especially if its a 3G signal as they dont travel as far as 2G. Whats it like if you call someone and you're stationary? Or move the phone around in the car (ie put it on the dash so it gets better signal)? If its still the same when not moving, I'd get it back to Nissan. Quote Link to comment Share on other sites More sharing options...
dragon Posted December 1, 2011 Share Posted December 1, 2011 Could it be the microphone itself? could be its not picking up properly, just a thought Quote Link to comment Share on other sites More sharing options...
andrew0401 Posted December 21, 2011 Share Posted December 21, 2011 Exactly the same on my 2010 Roadster - I can hear the caller no problem, but they say very difficult to hear me - usually very faint and distorted. Makes no difference where the phone is in the car, no difference whether moving or parked. Dealer view is that you should expect more background noise due to the soft top! Regards Andrew Quote Link to comment Share on other sites More sharing options...
Ebized Posted December 21, 2011 Share Posted December 21, 2011 I'm sure you have, but as it has not been mentioned on the thread so far........ Have you checked your outgoing phone volume is set at a high enough level? If not, go into "settings" - "Volume & Beeps" - "Phone Outgoing Vol" and adjust. (Page 8-5 of your owner's manual for the various ways to access if you are not sure) Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 21, 2011 Share Posted December 21, 2011 Background noise should not be an issue when the a car is parked with the roof up Bad dealer Exactly the same on my 2010 Roadster - I can hear the caller no problem, but they say very difficult to hear me - usually very faint and distorted. Makes no difference where the phone is in the car, no difference whether moving or parked. Dealer view is that you should expect more background noise due to the soft top! Regards Andrew Quote Link to comment Share on other sites More sharing options...
haynesml Posted December 21, 2011 Share Posted December 21, 2011 I do not have any problems with people hearing me in my roadster even when on the motorway. In fact people say its very clear, background noise is not an issue. Quote Link to comment Share on other sites More sharing options...
ChrisP Posted March 9, 2012 Share Posted March 9, 2012 Was there any conclusions made to this thread? I'm having the same issue with my handsfree kit, speed and road type seem to be irrelevant and whilst incoming audio is excellent I've been described as being in a fishbowl at best! I've been treating this as a warranty issue with the dealer who have changed both the microfone AND control unit so far, unfortunately to no avail... Quote Link to comment Share on other sites More sharing options...
andrew0401 Posted March 15, 2012 Share Posted March 15, 2012 Tried outgoing volume at a variety of setting (including 100%) - varies between inaudible and distorted. If I lean over and shout directly at the microphone then it seems to improve - just makes driving harder! Andrew Quote Link to comment Share on other sites More sharing options...
ioneabee Posted March 15, 2012 Author Share Posted March 15, 2012 nope - no resolution I've made the dealer aware of it and I'm going to try a different phone to see if thats the same - just haven't got round to it Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 15, 2012 Share Posted March 15, 2012 If you have tried the options in the manual: Volume The following kinds of phone volume can be set. Pushing the PHONE button and selecting the “Volume†key can also operate the same settings. . Ringtone/Incoming Call/Outgoing Call To increase or decrease the volume, select the “Ringtoneâ€, “Incoming Call†or “Outgoing Call†key and adjust it with the multifunction controller. and speaking towards the microphone in the centre roof section hasn't solved the problem, or trying a different handset dosen't improve things, then you need to get the Dealer to sort it. If they don't seem capable then contact Nissan Customer Services and if necessary insist on an inspection by one of their techies. I've never had an issue in my (pre-Premium Connect) 370, other than the usual signal breakdown Quote Link to comment Share on other sites More sharing options...
andrew0401 Posted March 23, 2012 Share Posted March 23, 2012 Found this. http://www.gtr.co.uk/forum/152628-step-step-guide-swapping-telephone-microphone-correct-side.html Investigated my roadster - and yes the microphone is passenger side and aiming slightly (10 degrees?) towards passenger, all you need is a hot screwdriver to make some mounting holes on the side facing driver and the result is the microphone is about 2 inches closer to driver but importantly aiming 10 degrees towards driver not 10 degrees away! People now say they can hear me more clearly - not brillaintly but a lot better than before! Andrew Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 23, 2012 Share Posted March 23, 2012 Interesting find Andrew. I wonder if its newer models they seem to have made this mistake with? Mine seems fine on a MY10 Connect Premium. Might try and pull it apart later and see Quote Link to comment Share on other sites More sharing options...
andrew0401 Posted April 3, 2012 Share Posted April 3, 2012 After having an investigate of another car (and chatting with friendly local dealer) - it is slightly more variable! Not only do some cars have them on left side rather than right side (even dealer does not know why!), whether you can "self-fix" depends upon how the cables has been routed. Sometimes there is enough slack to pull gently (as in my case), but in others it is necessary to remove the headlining so as to reroute the cable to create enough slack. I always thought the Japanese were rather good on quality control - all this variation in how they get built is a bit concening! Andrew Quote Link to comment Share on other sites More sharing options...
geoff hyman Posted November 3, 2012 Share Posted November 3, 2012 Hi - I have the same issue but I can be heard better when the car is stationary. Geoff Quote Link to comment Share on other sites More sharing options...
Robchriscross Posted March 22, 2016 Share Posted March 22, 2016 (edited) Managed to sort mine earlier as was on the handsfree yesterday ended up having to stop and disconnect to finish the call, firstly I turned the outgoing volume up to full then removed the light cover to discover my mic was on the passenger side and had no slack at all, I popped the inner frame out and undid the mic cable I then moved it across to drivers side put back together then while on the road rang the same person I was shouting at yesterday and was able to have a conversation without even having to shout took about 10 minutes to sort it hope this helps someone out ☺ Sent from my SM-G920F using Tapatalk Edited March 22, 2016 by Robchriscross Quote Link to comment Share on other sites More sharing options...
