High Clutch Pedal
eviljoker7075
Hi all. I am looking at buying my first zed. Over the weekend I tested two and found one that I'm interested in... However I noticed that the clutch was quite high, in comparison to the other.
I just wanted to check if this is a known or common issue - or if it should be considered a problem?
Any advice would be much appreciated.
Cheers!
Lots of posts on this...have a 'SEARCH' see what you turn up.
From my own experience, I bought a Zed with 42k on the clock with a high clutch, it went 2k miles later. Some people say their clutch is just high though and drives fine...
do you mean the bite is higher or that the whole pedal is higher?
If it's the biting point, then If it's high: It's on the way out. Go for the lower one.
It is of course possible they've adjusted the pedal position to personal preference. The higher one might be "normal" in terms of bite but the overall pedal is higher up.
