*Benj* Posted November 26, 2011 Share Posted November 26, 2011 hi, Relatively new to the forum, and apologies if this is a repetitive post. As I have discovered my 04 GT the pipe from the back box has come away from the flange, where the centre pipe meets the back box pipe. I have been to the local welders and have been advised that welding will not solve the problem as the flange piece is corroded itself. Can someone please advise my potential solutions and where to get the problem solved? I am from Manchester/ barnsley (s yorks) I cannot afford a new system at the moment, with Christmas approaching etc. Any help would be appreciated Cheers Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 26, 2011 Share Posted November 26, 2011 You could either ask the local welder to cut out the flange altogether and replace with a pipesection instead or go on the hunt for an aftermarket exhaust Quote Link to comment Share on other sites More sharing options...
Lexx Posted November 26, 2011 Share Posted November 26, 2011 You might find a second hand OEM unit around for about £100. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted November 26, 2011 Share Posted November 26, 2011 Welcome Along Quote Link to comment Share on other sites More sharing options...
nzr350z Posted November 26, 2011 Share Posted November 26, 2011 I have a good repaired backbox that i dont need, if interested let me know,live near J 28 of M1,am looking for £45.00 Quote Link to comment Share on other sites More sharing options...
skidder Posted November 26, 2011 Share Posted November 26, 2011 You could either ask the local welder to cut out the flange altogether and replace with a pipesection instead or go on the hunt for an aftermarket exhaust This is what my welder just did for me..cost me £60 + a tenner tip and its a solid job. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 26, 2011 Share Posted November 26, 2011 You could either ask the local welder to cut out the flange altogether and replace with a pipesection instead or go on the hunt for an aftermarket exhaust This is what my welder just did for me..cost me £60 + a tenner tip and its a solid job. You're welcome Quote Link to comment Share on other sites More sharing options...
*Benj* Posted November 27, 2011 Author Share Posted November 27, 2011 Thanks for the help. I was contemplating the pipe section option, but didnt know whether it would cause complications later. But enough people seem to have chosen this route, so it cant be that bad. Quote Link to comment Share on other sites More sharing options...
narcotix Posted November 27, 2011 Share Posted November 27, 2011 It's a very common issue on the exhaust system ... I had the same problem last year as well ... The welder I went to cut away the existing flange and replaced it with a similar flange he had lying around ... not had any problems with it since. Quote Link to comment Share on other sites More sharing options...
