nij1983 Posted November 18, 2011 Share Posted November 18, 2011 Hi all, Just wondering if fuel additives are actually worthwhile using every now and again to clean the engine and help to improve on MPG? Has anyone/ does anyone use these and how have they faired? And no, i'm not highly concerned about mpg, but as Tesco's says, every little helps Cheers Quote Link to comment Share on other sites More sharing options...
Karlp Posted November 18, 2011 Share Posted November 18, 2011 I would stay away from redex etc as I've heard bad stories about them been harsh on some engines and wearing fuel lines etc, I would stick to using super unleaded or a 97/98 ron as they already have additives and cleaning agents in them. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted November 18, 2011 Share Posted November 18, 2011 I would stick to using super unleaded or a 97/98 ron as they already have additives and cleaning agents in them. Shouldnt be using anything less anyway I had this kind of treatment done on my old 350z for free at the dealer and can say it made sod all difference to how the car ran and MPG. Personally I'd leave it alone unless you have a reason to use it. Quote Link to comment Share on other sites More sharing options...
nij1983 Posted November 18, 2011 Author Share Posted November 18, 2011 I always use Super unleaded. Only used unleaded when the car was really low on fuel and the petrol station didn't do Super! Thanks for the comments. I figured fuels have come a long way since several years back and can't see why they wouldn't have their own engine cleaning additives (e.g. v-power). Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 18, 2011 Share Posted November 18, 2011 I used some redline stuff about a year ago. Was about £6 said it had the highest temptetire detergents. Did it make any difference? Not that I could tell. But for £6 it felt like I had treated my car and felt like slight peace of mind. So can't complain. I always use Super unleaded. Only used unleaded when the car was really low on fuel and the petrol station didn't do Super! Thanks for the comments. I figured fuels have come a long way since several years back and can't see why they wouldn't have their own engine cleaning additives (e.g. v-power). Quote Link to comment Share on other sites More sharing options...
Zugara Posted November 18, 2011 Share Posted November 18, 2011 It doesn't work, 5th gear did a comprehensive test on these products and found the you were just wasting your money. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 18, 2011 Share Posted November 18, 2011 It doesn't work, 5th gear did a comprehensive test on these products and found the you were just wasting your money. No that was octane boosters and their test was super flawed. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 18, 2011 Share Posted November 18, 2011 BG44K is what i use in my Jag, worked to good effect, and helped clean up my injectors which were stuttering at the time. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 18, 2011 Share Posted November 18, 2011 BG44K is what i use in my Jag, worked to good effect, and helped clean up my injectors which were stuttering at the time. sounds like some good stuff. Where did you get it from? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 19, 2011 Share Posted November 19, 2011 BG44K is what i use in my Jag, worked to good effect, and helped clean up my injectors which were stuttering at the time. sounds like some good stuff. Where did you get it from? ebay was my friend on this one. i tried something like STP or Redex before but it didn't do much. got reccomended the BG44k and i saw an improvemnt within 2 tanks of fuel. best to use it in a full tank, run it down to half empty and then fill tank back up, then run tank to empty and fill to top again. its alot stronger than anything else on the market. BG do a load of other stuff, not tied anything else but they do octane boosters as well; check out their website, i think you can order from there as well. my engine is 11 years old and had some miles on it. if you notice it on the zed i'm unsure. but the V8 certainly liked it. will probably run another can through again next year. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 19, 2011 Share Posted November 19, 2011 BG44K is what i use in my Jag, worked to good effect, and helped clean up my injectors which were stuttering at the time. sounds like some good stuff. Where did you get it from? ebay was my friend on this one. i tried something like STP or Redex before but it didn't do much. got reccomended the BG44k and i saw an improvemnt within 2 tanks of fuel. best to use it in a full tank, run it down to half empty and then fill tank back up, then run tank to empty and fill to top again. its alot stronger than anything else on the market. BG do a load of other stuff, not tied anything else but they do octane boosters as well; check out their website, i think you can order from there as well. my engine is 11 years old and had some miles on it. if you notice it on the zed i'm unsure. but the V8 certainly liked it. will probably run another can through again next year. How many treatments does one can give you? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 19, 2011 Share Posted November 19, 2011 1 can = 1 treatment. it all goes in instructions can be found on the can and on the website as well i think Quote Link to comment Share on other sites More sharing options...
