Tyre Pressure Query
chriswatson99
Hi Folks,
I've just been on the Vredstein website and noticed that their suggested tyre pressures for both the Ultrac Sessanta and Wintrac Xtreme's are 39 psi for the front and 42 psi for the rear.
Does this not sound a bit high to you guys?
Pretty sure it says on the inside of the drivers door that 35psi is recommended for the front and back.
Thanks,
Chris
  • 3 months later...
any ideas what to run with 275 30 20 prelli p zeros on rear and 245 35 20 0n front
The correct size tyres would be a start. Should be a 30 profile on the front too.
As for pressure.
Start at 35 psi then adjust up and down until you find something you're happy with.
