Intel Mini ITX Motherboard - Atom N270 CPU Fanless
cerealuk
I have a few of these available. All brand new as per the photo. They came as a bulk lot of OEM system builder units so are in plain brown boxes but are complete and sealed
More info at: http://www.intel.com/products/desktop/m ... erview.htm
Looking for £69 Delivered
These run off 12v so could be ideal for car PCs.. you will need to buy a separate power supply though as it doesn't come with one. You will also need ram+case+hdd
They are fanless so are silent :)
Intel D945GSEJT Low Profile Mini ITX Motherboard
Intel is enlivening the Net top market and enabling innovative system designs with a radically thin, low-power motherboard based on the Intel® Atom™ N270 processor. The D945GSEJT, AKA Jothnstown, is designed for users demanding affordable yet stylish Internet-centric computing solutions. This breakthrough platform addresses emerging slim Net tops, affordable all-in-one PCs, thin/enriched-client PCs, and other usage models with its versatile, low-power, thin form factor design.
Even though the board is just 20mm high it is still packed full of features including built in DC to DC power supply, VGA/DVI, and LVDS video outputs, GbE LAN, Mini PCIe card slot, 2x SATA connectors, 1x 44 pin IDE, USB 2.0 expansion headers, and more. The low power 1.6GHz N270/GSE chipset have a TPD of just 9W allowing for a fanless/passively cooled design. When the D945GSEJT is paired with a solid state hard drive it creates a completely silent PC with no moving parts. The standard height I/O shield has 3 knockouts for standard 8mm 802.11 antennas
Processor 4W 1.6GHz Atom N270 w/ 512Mb Cache
Chipsets Intel 945GSE Northbridge
ICH7-M Southbridge
Total Power Draw 5 watts
System Memory 1 DDR2 533/667 SO-DIMM slot (validated to run at 533 MHz)
Up to 2 GB
Graphics Integrated Intel GMA 950 Graphics
Supported Resolution
VGA: 2048 x 1536 maximum (QXGA)
DVI/LVDS: 1600 x 1200 maximum (UXGA)
Expansion Slots PCI
PCI Express Mini Card
Onboard IDE 1 ATA 100 44-pin
Onboard Serial ATA 2 SATA (3 Gb/sec.) connectors
Onboard USB 7 USB 2.0 3x I/O and 4x via internal headers
Onboard LAN Realtek RTL8111DL GbE 10/100/1000
Onboard Audio Realtek ALC662 5.1 channel HD codec (2+2 channel audio subsystem with S/PDIF)
Back Panel I/O 3 USB 2.0 ports
1 VGA port
1 DVI-D port
1 LAN port
1 Audio jack: line-out
DC jack (12-volt input)
Onboard I/O Connectors 4 USB 2.0 via 2 pin headers
1 P4 power connector (for peripheral 12v power)
1 Molex connector (for SATA power)
2 SATA connectors
1 RS-232 COM pin header
1 PS2 keyboard pin header
1 Parallel port pin header
1 Front panel audio pin header
1 S/PDIF pin header
1 Fan pin header
1 LVDS connector
1 LVDS inverter
1 Chassis intrusion pin header
BIOS Intel BIOS 4 Mb flash memory
Operating Temperature 0ºC ~ 55ºC
Form Factor Mini-ITX (17 x 17 cm)
Also Included Installation CD
Backplate
2 SATA cables
1 SATA power cable (1 Molex to 2 SATA power)
Quick reference guide
