cmck13 Posted November 3, 2011 Share Posted November 3, 2011 Decided to remove this to enable a new paint job on it. Read up on the guides no problems here, but when attempting to remove the main electrical cable block that I assumed would be a simple pull out job, it feels well and truly stuck. Is there any special push in part as a clip I need to know about or should it just pull straight out? I haven't gave it the full hog yet for fear of breaking anything, thanks in anticipation. Jeff Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 3, 2011 Share Posted November 3, 2011 Decided to remove this to enable a new paint job on it. Read up on the guides no problems here, but when attempting to remove the main electrical cable block that I assumed would be a simple pull out job, it feels well and truly stuck.Is there any special push in part as a clip I need to know about or should it just pull straight out? I haven't gave it the full hog yet for fear of breaking anything, thanks in anticipation. Jeff If you mean the throttle body then there is a release clip on the block connector Do not force it off Quote Link to comment Share on other sites More sharing options...
cmck13 Posted November 3, 2011 Author Share Posted November 3, 2011 Decided to remove this to enable a new paint job on it. Read up on the guides no problems here, but when attempting to remove the main electrical cable block that I assumed would be a simple pull out job, it feels well and truly stuck.Is there any special push in part as a clip I need to know about or should it just pull straight out? I haven't gave it the full hog yet for fear of breaking anything, thanks in anticipation. Jeff If you mean the throttle body then there is a release clip on the block connector Do not force it off Thanks. Yes I do mean the throttle body and thats what I thought it might be but I dont see a clip or anything on the block connector that gives. Is it the flat part on the right handside of the block that faces to the nearside of the car? do you push it in etc? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 3, 2011 Share Posted November 3, 2011 Just press in the outmost part of the flat section and it will release. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted November 3, 2011 Author Share Posted November 3, 2011 Cheers Alex Another +1 for you. Quote Link to comment Share on other sites More sharing options...
