Krissg Posted October 31, 2011 Share Posted October 31, 2011 Right, sorry if I come across as a total idiot but what are the main benefits of using lightweight ally pulleys? Cars in the garage shortly for my new racing clutch and fly so seeing what else I can do while I'm at it! cheers Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 31, 2011 Share Posted October 31, 2011 Plenum spacer and up rev will have better gains than lightweight pulley's. Quote Link to comment Share on other sites More sharing options...
Southernspeed Posted October 31, 2011 Share Posted October 31, 2011 Any weight saving in rotating masses will help the engine spin up faster. Go too far though, like a really light flywheel for example and you can effect idle smoothness and lose engine braking, but's quite extreme lightening. Quote Link to comment Share on other sites More sharing options...
Daryl Posted October 31, 2011 Share Posted October 31, 2011 I have a set of AMS uprated pulleys fitted to my 350. I think it spins up abit quicker than it did before. Really noticed it in 6th gear while doing 30mph,then accelerating,seems to spin up abit better than it did before. Quote Link to comment Share on other sites More sharing options...
Daryl Posted October 31, 2011 Share Posted October 31, 2011 Plus,if you felt the weight of the standard pulleys,you would change them,as the standard ones weigh alot! Quote Link to comment Share on other sites More sharing options...
Krissg Posted October 31, 2011 Author Share Posted October 31, 2011 Plenum spacer and up rev will have better gains than lightweight pulley's. Iv already had the up rev and just in process of looking for a plenum. Presume they aren't too much of a job to fit? Bumper and rad off ? Quote Link to comment Share on other sites More sharing options...
coldel Posted October 31, 2011 Share Posted October 31, 2011 Seen guides for plenum fitting on here if you do a search - some on you tube too i am sure. As far as I know plenum install is a case of .. removing the upper plenum, which is under the strut bar and engine cover Quote Link to comment Share on other sites More sharing options...
Krissg Posted October 31, 2011 Author Share Posted October 31, 2011 Seen guides for plenum fitting on here if you do a search - some on you tube too i am sure. As far as I know plenum install is a case of .. removing the upper plenum, which is under the strut bar and engine cover Oh ye iv done some research into the plenum, I was referring to fitting of pulleys though! Hahaha Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 1, 2011 Share Posted November 1, 2011 There is a few ways. You could lock the fly wheel. Or you could put it in 6th to crack the pulley bolt. Or you could use a strap wrench in one direction and a breaker bar in the other. Some people use a "cheater" bar. They jam the breaker bar on the floor and start the engine to crack it. Check out the US sites for more info. Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 1, 2011 Share Posted November 1, 2011 Did mine the other day - they can be tight! My engine is out so easy for me You don't want remove the rad - you would need to de-gas the air con to take it out completley and get in that way. Quote Link to comment Share on other sites More sharing options...
