Darren-B`s Vortech Fun & Games
Darren-B
So over the winter I have a few bits I need to do on the zed to keep her at her best,
A week before the Jockland Hoon I gave her a service, spark plugs, engine oil, coolant, gear & diff oil. When changing the plugs I discovered that there was a small amount of oil leaking from the rocker covers into the sleeve for the no.1 & No.4 plugs. I spoke to ZMANALEX whilst on the hoon about this & he advised that the centre seals are part of the rocker cover & a new rocker cover would be required. So against his advice I ordered the replacement rocker cover gaskets (outer Seals), sub £20 delivered. With the intention to replace the outer rubber seals & make/repair the centre seals with a heat & oil resistant sealant rather than fork out for replacement rocker covers. So the last couple of evenings I got to work to repair the leaks.
Before I started, completely stock other than a panel filter, 06 velocity stack & plenum spacer.
Engine cover & strut bar removed
coolante drained, then upper & lower plenum removed
Then came the slightly trickier part of un fixing & moving the various coolant hoses & the main wiring loom to gain access to the rocker covers.
This in fact took more time than it did to actually remove, clean 7 replace the gaskets on both covers. Unfortunately I didn`t manage to get any pics of the covers off as it was getting a little late & I wasn`t going to get cleaned up just to take pictures.
Rocker covers fitted, torqued & cleaned, wiring loom & coolant hoses back in place
Re-fitted the lower plenum, cleaned & torqued. Then went to work on the upper plenum, fancied a colour change, Red :) So i prepped & sprayed the upper plenum Rosso Red (matt)
After putting it all back together bar the engine cover & strut brace I decided that I could see to much of the aluminium on the lower plenum so that needed painting to, also I thought it would look better with some lacquer :D
I also painted the strut bar but forgot to take pics
Lower plenum, installed once again
Then upper plenum installed
Strut brace, engine cover & intake installed
Finally the coolant was replaced & fired her up, :teeth: All seems 0k, no signs of any leaks, in fact it feels alot quicker :drive1 it must be the Rosso red paint, that must be worth 50hp :lol:
Next on my list are,
Replacing hinges on drivers door
Replacing Clutch & Flywheel (single or DMF)????
Finding a faulty airbag connection
Cleaning & sealing all ali parts under the car,
Under-sealing
Re-spraying the bonnet, bumper & wings
Removing & re-furbing Brembo callipers
Possible poly bushing
Doesn`t look like I`ll be spending much time with the better half this winter :sly:
  • Replies 158
  • Created
  • Last Reply
Top Posters In This Topic
Nice work :thumbs:
I know what you mean whe you say -
"Then came the slightly trickier part of un fixing & moving the various coolant hoses & the main wiring loom to gain access to the rocker covers."
Did waltzinblack's a couple of weeks ago OMG :lol:
All looks good painted - did you use ordinary paint on the plenum? or something for heat?
does the underfloor heating work well on the garage door? not an expected question i know
Believe it or not the wall is made of foil wrapped glass with the underfloor heating stuck on top, primarily used for painting glass (the underfloor heating is used to bake the paint) :)
I keyed the surface with a wire brush drill attachment, then cleaned with cellulose thinners, blasted with compressed air, grey primed then painted with a water based glass paint mixed with a hardener, should be good for upto 190'c. If my plenum gets that hot it won`t be the paint I`ll be worried about. Then used a 2k lacquer
I painted the rocker cover of my MX-5 with a standard water based body paint & that held up at much higher temps than the zeds plenum ever gets to
So in my opinion I would think that so long as the part you wish to paint is not getting excessively hot (some form of heat shield) if the item is prepped correctly & painted correctly the paint should last
Nice work buddy, just need to paint that engine cover now, silver or black? B)
Cheers :thumbs: The engine cover is black :teeth:
:offtopic: but that is a really nice shower.....
I can do them any colour you like ;) Thats where the Rosso Red came from, just done a kitchen for a Ferrari Fanatic
Nice work Darren thats some good stuff there great spray job to!!i got a blade silver one so if its the KYO when you do your bonnet/wings interested in doing a door at the same time??? i want something in my engine bay painted now too :lol:
Tbh silver is a right bugger as you can never get a perfect match so if you were to paint a door, to make it look perfect you will have to blend it in by painting the front & rear wings, I repaired a door, bumper & wing on my silver mx5, ended up painting nigh on the whole car to get it to not show up in the sunlight. :scare:
Looks really nice. that red is such a nice colour. did this bloke get you spraying his whole kitchen then?
my boss brought in some spray guns a few months ago with the idea that we could spray our own electrical panels. he said i can use it whenever i want so i might give it a go.
will have to try out on something not Z related to get the hang of it first.
before you tell me off i'm aware of the dangers and precautions required when spraying ;)
Of course the old - spare pot of rosso red kitchen paint laying around - trick :lol::lol:
Nice one, I asked as my plenum gets hot - a lot hotter than others when we compared on track days!!
will see how it goes may paint it yet????..... may polish it up
Thanks for letting me know :thumbs:
