TheGrinch Posted October 21, 2011 Share Posted October 21, 2011 Is there a way to check the condition of the dampers when they are still on the car? Is there a typical number of miles/years when they start to wear out? Quote Link to comment Share on other sites More sharing options...
marzman Posted October 21, 2011 Share Posted October 21, 2011 Look for leaking fluid from them for a sure sign that they're shot. Also a visual inspection of the rubber mounting at the top of them should also give a good indication of the life left on them. Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 22, 2011 Share Posted October 22, 2011 Push down a couple of times at each corner, the car shouldn't bounce. If it does, that shock's gone. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted October 22, 2011 Share Posted October 22, 2011 Let me drive it, I`ll let you know how good the dampers are On a serious not, do the above, but if you have a damper gone when you drive over bumps the car will tend to sway/wallow about. If your still unsure take it to your local MOT centre & have it checked properly Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 22, 2011 Share Posted October 22, 2011 Let me know if you need any. I have loads from sub 1,000 mile cars so they are virtually new Quote Link to comment Share on other sites More sharing options...
