Speedometer Removal Guide
live2themaxuk
Hi there
is there a guide anywhere which illustrates how to remove the speedometer/tachometer assembly?
Ive got some vaugue instrctions but some picture of how to would be great
any ideas?
Jamie
10 min job , undo 4 screws that keep shroud around steering column, first pop out trim ring round ignition switch... then there are 4, 10mm head bolts that retain speedo assy to the steering column undo these (they are a bit fiddly and you will need a small ratchet with longish extension bar to get at the front ones ) and thats it just unplug the single electrical connector and the speedo assy will be in your hand !! :thumbs:
