Cover plate for flywheel
Dblock
Hi guys Im going to be doing my pulleys soon and my car is an auto so the normal put it in 6th and hold the brake wont work.
No ive read from zmanalex and other people
"removed a small coverplate from the bottom/corner of the transmission and put a special tool (flathead screwdriver) carefully into the hole which pinned, what I believe was the flywheel. Which is located on the engine side of the tranny & will prevent the crank for rotating. He had a lift of course."
There should be a cover plate that you can stick something in to stop it turning, which stops your crank turning and then I can bust the nut off and put my light weight pulley on :) Ive got a nice 1/2" snap on air gun to break the nuts too but ideally I would want to do it without stressing anything.
Any one have any idea where this plate is? A picture would be fantastic if anyone has one?
All help is much appciated. Il try to make a guide for doing it too :thumbs:
