clutch slave cylinder
bigsigh
Its easy if your handy with the spanners :thumbs:
Under the car remove the rear gaurd thing - look up on the passenger side of the gearbox - 2 bolts IIRC and a banjo bolt for the clutch line, new one in bleed it up away you go.
Simples :)
If I recall correctly, its the '07 onwards HR model that has the slave cylinder concentric to the gearbox input shaft, in place of the thrust bearing. You've got to remove the gearbox to change that one.
I think on yours you'll be okay as Keyser said - have a quick look for it undeneath and you'll know for sure!
Correct
