help! dead battery and need the car
rog518
Hi all,
just went to start the car and have a dead battery! The lights on the dash are flickering and it has some life but not enough! Just read its not safe to jump start! is that true? Can get a charger but need the car by 5pm! Any suggestions?
Thanks Rog
Cheers Cragus did you just use standard jump leads to another car? May trickle it for the day and then use that as a last resort! First time its done it in 18mths been in garage for the last 6mths too! havent used it for over a mth tho! Booo!
Standard leads with other car running for a min or two. Then start the zed. Take the zed for a lengthy zed to give it's battery a good charge and you should be golden. :thumbs: I wouldn't even bother with a trickle charge.
