Project Zee Business - Update 25th July
Keyser
Something a bit more interesting this weekend -
Installed and tested the AAM Competition 350Z Stage 1 Fuel Return Kit.
The reason this is being installed before the engine swap is that so many parts will be changed in one go I thought, if I install, test and prove some parts working they are less likely to be an issue when the new engine goes in should any problems arise.
It started of looking like this
The workshop foreman immediately took up position
Stripped the plenum etc out -
Then out with the stock fuel rails
Removed the injectors and got all the new bits together
New fuel rails installed
Installed the new fuel regulator and test gauge.
On Sunday Bob popped round to play - Be warned keep clear of Bob and a pair of pliers
I'm not sure if he was planning on lowering the car at this point
Fuel pump assembly removed -
Modified and installed - nice neat job
New return fuel line mounted next to existing fuel feed line -
Pressure test -
We had 2 leaks to deal with when tested to 90psi One was a missing rubber washer the other is where the new braided fuel feed line connects to the original metal fuel line - this is due to the kit re-using the OEM connector - which I don't have - must have been removed at some point in the past. We have done a temporary fix at the moment with jubilee clips (that's when bob tried to remove my finger ) I will be replacing this with a proper aftermarket connector later.
So the senior mechanic put her back together -
Back to this
The only sign we were ever here -
.................. That's all folks
  • Replies 177
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  Wasso said:
Just love the site foreman, looks kinda familiar to any site.
As Andlind says we'll all be at yours for install requirements. I'll be giving you a nice simple project for you next year ;)
Bring em on :thumbs:
Please remember all my work comes with no guarantees and only a 70% chance of success :blush:
If you've got the Zed and you can find it you'll always be welcome at the Zed Shed
:p:lol::lol::headhurt:
Another quick update -
Mrs Soze did this mod but thought I should post any way :)
My Bride seats -
Came with a piece of Bride material in one of the boxes - maybe they all do?
So my good lady wife popped to the material shop got the sewing machine out - I'm not qualified to explain what came next :headhurt::scare:
But then this happened
and by Sunday night I had custom made seat covers :yahoo:
  Neilp said:
:lol: missing NOS though
  rodgeevans said:
Sperad that lot out on the floor in one picture and it would remind me of the porn shot in the original fast and furious, nice job mate will look on this one with interest.
Wizard 75 shot on its way :yahoo::scare::drive1
:lol::blush:
:lol::blush:
That's a good plan, where did you get that idea from :disguise:
NOS is sold to the Zed shed :thumbs:
  Wasso said:
:lol::blush:
Yes that reminds me
Special thanks now also go to Wasso for a superb assist in the "Lets deplete Keyser's bank account" challenge :bang:
  andlid said:
Mad man
What were your dyno figures again Muhaaaaaaaaaaa!!!!
Coming for you mate :thumbs:
I believe the Ring next summer is the venue?
Assuming she dosn't blow up on the dyno!
:lol:
  Karate Chimp said:
Bloody Awesome! If you need some help (even if it's just a teaboy) let me know; I'd love to have an excuse to be around whilst that Badboy is being suped up! :thumbs:
You've got my number - drop me a text the Brew boy post is vacant :thumbs:
Couple of new bits arrived this week :D
Some new (to me) 19" BK Racing Alloys - these will be my winter/road tyre wheels the Rotas with the R888's will be kept for summer/track
Don't they look similar to the Ginger Ninja's wheels??
4 x 20mm spacers for the BK's
My new LUKE 4 point harnesses to go with the Brides.
Started the Oil Cooler install this weekend but broke my oil pressure sender while sorting out the pipe routes :bangin: so I can't hook it up until the new one arrives around Wednesday.
First attempt at a mock up location - Fail!! as the FMIC pipe means it to far forwards :surrender:
So onto location 2
This works as the FMIC pipe is smaller on this side and I can get the rad back far enough
So made up some mounts with the assistance of my Daughter and Bob and we fitted it in.
Had to trim the bumper a bit so it doesn't rub.
All in place -
Will hook the pipes up and update soon.......
That's all folks ...........
  Neilp said:
Looking brilliant mate!! Love watching this. Wish my garage was as big and organised as yours lol. :thumbs:
Don't forget the really good lights :lol:
  andlid said:
Nice work, bolts is what I need to do with mine. No braided lines!:) it is a thermostat in that I take it?
They are braided - internally - rated to 160 Bar yes BAR!!! LOL I's not like they will be seen is it?
I have a thermostatic sandwich plate but need my new oil pressure sender before I install it :headhurt:
Will get pics up when I get the next bit done :thumbs:
Oil Cooler Part 2
Evening all
So still waiting for my new oil pressure sender but my oil pressure tester arrived today so I thought I'd get the oil cooler moved on a step.
It actually went quite well even though I got covered in the stuff when I dropped the pipe
So started off with this -
Quick oil pressure test (cold)
Unfortunately when I lined the sandwich plate up I could see a slight problem with the location of the Oil Pressure sender :bang:
Added some elbows to move that round -
Bolted it all in place
Test run time
Assisted by my daughter as always - her job was to scream if the oil pressure went below 20 psi
Oil warmed pressure holding -
Did discover that my 80 degree sandwich plate opens at 70 degrees!!??? :shrug:
Input temp -
Output (not bad for stationary)
Think these will hold the pressure
All plumbed in -
Hopefully get my oil pressure sender tomorrow or Thursday - hook that up and a test drive. :drive1:yahoo:
That's all folks .....................
