scootz Posted October 5, 2011 Share Posted October 5, 2011 Howdy Y'all Brand spanking new in here, so go easy! I've been contemplating a Seven-type kitcar build with a 350Z engine for a while now. I hopefully have a window in my project calendar starting next year, so I took the plunge and got myself a non-running core-engine to strip and re-build with some trick bits! No idea what was wrong with the engine yet... the external cases are all structurally good... I wonder what I'll find inside!!! Anyway. The plan is to fix whatever has made it sick and then complete with a set of cams, Jenvey throttle bodies, straight through exhausts and aftermarket ECU. I'm hoping for 300hp... which in a 550kg rear-wheel drive car should be quite, erm, lively! Unfortunately I don't have any details from the car that the engine came from. I see it is the non 'rev-up' variant, but I've no clue beyond that! I'm a little puzzled about the engine number though... it has the serial-number and ends 'VQ35', but there's no further letters after that (I would have expected a 'DE' or the likes... can anyone shed any light???). Let the stripping begin! Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 5, 2011 Share Posted October 5, 2011 interesting Quote Link to comment Share on other sites More sharing options...
seamybaby Posted October 5, 2011 Share Posted October 5, 2011 super should be rapido indeed!!!! had a westfield megablade a few tears ago and it was... Quote Link to comment Share on other sites More sharing options...
Lexx Posted October 5, 2011 Share Posted October 5, 2011 Looking at the pic you've put up, it is a VQ35DE. If its non rev-up then its 276bhp as standard when in a Zed. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted October 5, 2011 Share Posted October 5, 2011 welcome along Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted October 5, 2011 Share Posted October 5, 2011 Welcome to the forum... Quote Link to comment Share on other sites More sharing options...
Keyser Posted October 5, 2011 Share Posted October 5, 2011 Hello and Welcome Looks like a fun project Quote Link to comment Share on other sites More sharing options...
scootz Posted October 5, 2011 Author Share Posted October 5, 2011 Cheers fellas! It was going to be a V8 build, but the more that I read about the Nissan V6, the more I realised that it would offer more than I could ever use. It should also be a fair bit lighter than a V8 (will weigh it at the weekend). I'll be using the 350Z gearbox with it... and most likely the Nissan LSD. I just hope that the inside is not as chewed up as it could be! Oh well, I guess there are plenty of nice and shiny aftermarket bits out there if I do need to replace rods, pistons, or cranks! I take it the fact that the engine number just ends VQ35 and not VQ35DE is neither here nor there? Quote Link to comment Share on other sites More sharing options...
Lexx Posted October 5, 2011 Share Posted October 5, 2011 If you require OEM parts for the car (loom etc) then we have a resident trader who has all that kinda thing in stock "ZMANALEX" The VQ35 comes in 3 guises. 2 DE models are the non rev-up (276) and the rev-up (296) then there is a VQ35HR (309). Quote Link to comment Share on other sites More sharing options...
Maccaman Posted October 5, 2011 Share Posted October 5, 2011 Hi & to the forum. Look forward to a very interesting build thread. Quote Link to comment Share on other sites More sharing options...
MK-Ultra Posted October 5, 2011 Share Posted October 5, 2011 Hello and welcome Look forward to seeing this project build. Don't forget to keep posting your progress. Quote Link to comment Share on other sites More sharing options...
Vik54 Posted October 5, 2011 Share Posted October 5, 2011 Welcome to the forum Looks an interesting project Quote Link to comment Share on other sites More sharing options...
Ian Posted October 5, 2011 Share Posted October 5, 2011 Quote Link to comment Share on other sites More sharing options...
Stew Posted October 6, 2011 Share Posted October 6, 2011 Brilliant project. I'll be very interested in seeing it come together. I hope you've researched ITBs thoroughly...... Adam@Z1 has a 'built' NA engine with 300WHP. Sounds awesome but it it has had mega money spent. I think the ITBs might be very difficult to make work..... Vortech Supercharger could offer a great sound to a 'Seven' and give you 400bhp. Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted October 6, 2011 Share Posted October 6, 2011 Hi , sounds a good project; ITB work well on these motors if you use a aftermarket Engine management system , DTA have worked out how to use the stock flywheel pick up's , so you dont have to add a 36-1 crank trigger. They can also control the cam control. We can allow you to keep the whole stock engine ECU and wiring and fly by wire thou, which will make it a real easy install , there is only a few wires to connect via relays to allow the car to be run on a stock ECU ( we can also turn off the NATS code to help you) to run 300bhp you dont need to do any internal work. But if you stripping the motor , a set of cams and a increase in compression ratio will help. The limiting factor on the DE motor is the con rods and valve train w ehave found. Any questions ask away. Mark Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 6, 2011 Share Posted October 6, 2011 to the forum Quote Link to comment Share on other sites More sharing options...
scootz Posted October 6, 2011 Author Share Posted October 6, 2011 Thanks guys. I had a bit of time spare today so whipped off one of the heads. It was going far too smoothly, and then I broke the timing-assembly cover... I just don't know my own strength!!! I never noticed that there were 2 vertical bolts coming up from the sump at the bottom of the cover. Oh well... won't be doing that again. Plenty of shrapnel in all 3 offside cylinders... I wonder where I'll find the culprit(s) of the mayhem!? I've not had a chance to inspect all the valves yet, but it looks like they might have just about survived. Quote Link to comment Share on other sites More sharing options...
scootz Posted October 6, 2011 Author Share Posted October 6, 2011 Oh well... my £350 gamble didn't pay off! Took the other head off and found that someone (probably France) had been nuclear testing inside the block! Armageddon! So I have one good head assembly... one head (core) that just might be salvageable... timing-assembly... rocker covers... and a sump! I haven't had a proper look form the bottom, but reckon there is now't salvageable in the crank assembly and the block looks knacked! Back to eBay methinks... unless, of course, anyone on here has a block going spare! There are pics of the carnage in my album... and, yes... that strange meteorite-like item used to be a piston! Quote Link to comment Share on other sites More sharing options...
scootz Posted October 6, 2011 Author Share Posted October 6, 2011 Quote Link to comment Share on other sites More sharing options...
bronzee Posted October 7, 2011 Share Posted October 7, 2011 What an interesting project. Definitely keep us posted. Quote Link to comment Share on other sites More sharing options...
Snapon Posted October 7, 2011 Share Posted October 7, 2011 Hi welcome your project sound class I have spare complete 350z engine that needs a little attention Quote Link to comment Share on other sites More sharing options...
Mega Posted October 7, 2011 Share Posted October 7, 2011 Bit of T-cut will do it. In all seriousness that is ridiculous. Wonder what happened to do that to a piston!!! Quote Link to comment Share on other sites More sharing options...
Dom187 Posted October 7, 2011 Share Posted October 7, 2011 Wow looks like someone tried to run it on nitro glycerin! Keep us updated, one day I would love to have a VQ35 powered kit car and I would be interested to see how you get on Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 7, 2011 Share Posted October 7, 2011 Mate I have a low mileage VQ35DE with FSH and gearbox attached. The engine has every ancilliary still on it and the wiring loom. It is dry stored in a heated garage and I can supply an ECU that Abbey can remap for you to nearly 300bhp and turn off the NATS. Many of the scrap yard engines you will find are exactly that 'Scrap'. Even some suppliers store them outside with a tarp thrown over them PM sent Quote Link to comment Share on other sites More sharing options...
R35LEE Posted October 7, 2011 Share Posted October 7, 2011 I also have another engine with a noisy bottom end for parts only Quote Link to comment Share on other sites More sharing options...
