LED's all round
John tarantula
had the car a few weeks now and despite promising myself I would leave as standard have already ditched that :D
Ordered and fitted these for the rear numberplate: http://www.ultraleds.co.uk/501194t10-anti-bulb-warning-xenon-white-wide-angle-p-2085.html
these for the front sidelights: http://www.ultraleds.co.uk/501t10194-ceramic-watt-ultra-xenon-white-p-2395.html
which i fitted without taking the wheels or whole arch liner out :p (just one screw, pulled the cover back and used long nose pliers) so the outside is looking nice and modern.
just ordered these for the inside cabin lights: http://www.ultraleds.co.uk/high-brightness-xenon-white-smts-bulb-p-2392.html
and this for the boot light:http://www.ultraleds.co.uk/501194t10-mini-light-tower-leds-xenon-white-original-p-2191.html Hope it fits inside casing and isn't too long! should be fine as long as I can get it into holder.
Time to see if there are any front indicator bulbs I can get now :teeth:
feck, forgot about those bulbs! will wait til i get the latest lot then do a mop up order :)
If you can work out the right bulbs and the right way to replace thenm, I will be super impressed!
Been asking Husky to tell me what to get for a while and had nothing back (the guy is pretty busy) so if you can work it out, that would be great!
Would these help?
ok took a look at my own ones and they look like this:
doesnt make much of a difference really as you can just make up a bespoke light anyway, yours look like it would be easier to do as a custom job anyway. all you need to do is get hold of 1 LED and the correctly matched resistor. solder the resistor to the LED and put it in place of the bulb (the right way round). use 14.5V as your operating voltage and choose a decent brightness LED.
Hi mate,
So these LED's: "just ordered these for the inside cabin lights: http://www.ultraleds.co.uk/high-brightn ... -2392.html" Worked fine? was thinking of changing those lights but was unsure myself as to which ones to get?
Cheers, Lionel.
Yes worked fine for me! polarity sensitive though so they only work one way around. No where near the centre bit that can short and blow the BCM. have a read of this thread for more info: http://www.350z-uk.com/forum/viewtopic.php?f=35&t=37554
