balla Posted September 23, 2011 Share Posted September 23, 2011 right im picking up the k1 on Saturday from a member on here but hes keeping the brackets can anybody tell me what i need to make to make it fit pics will be much appreciated Quote Link to comment Share on other sites More sharing options...
balla Posted September 23, 2011 Author Share Posted September 23, 2011 and what size fire ring i will need Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted September 23, 2011 Share Posted September 23, 2011 What brackets? Ive a K1 on mine and theres no brackets. It comes in 3 pieces. The long middle section, then 1 section incl each silencer (hahahahahahaahaaaaa) piece. The mounts are welded to the pipes, so they just slip in the standard rubber mounts on the car. I used 2 nut & bolts to clamp each bit together. The long front section will just bolt to the studs on your Y pipe. The gaskets were normal 3inch bore ones. I got mine off ebay, but you can pick them up from most places. Good luck with fitting, I found mine was a total nightmare trying to undo the old rusty nuts on the standard exhaust. In the end I just took an angle grinder & an air chisel to it as I lost my temper with it. Quote Link to comment Share on other sites More sharing options...
Zugara Posted September 23, 2011 Share Posted September 23, 2011 Bet he means the rubbers. Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted September 23, 2011 Share Posted September 23, 2011 Bet he means the rubbers. Yeah me too, not much else it could be! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 23, 2011 Share Posted September 23, 2011 if its a japspeed then this is the best pic to make it fit Quote Link to comment Share on other sites More sharing options...
