Cruise Control Steering Wheel Panel
rodgeevans
This car is a JDM car Alex;
Yip I know Mark :thumbs:
I have a selection of switches here off 350Z and G35.
However the loom off the Cruise switch goes into the same connector as the Phone/Audio switch loom that connects to the Angle sensor. In other words the wires from both switches amalgamate before hooking up with the Angle sensor.
I can see no difference between the 350Z and G35 switches and the connector appears to be the same.
The only difference that is obvious to me is that the wiper and light combination switches are on different sides.
Perhaps you can advise what the differences are. :)
Yep this is not about fitting cruise control rather fitting the controls to allow multi maps to be run. although having trouble finding a torx plus bit to remove current steering wheel. :bang: does anyone no the correct bit TR?
Its a T30 but you need to get the tamper free version :thumbs:
I picked up a whole case of them on amazon for about £10 :)
