Freak accident!
Marios
My car was parked outside my work which is on a quite a steep gradient. The car was parked there for over 1 hour before it decided that it did not want to be parked there no longer so it decided to roll down the car park, cross a busy roundabout, mount the curb and smash into a ford escort....
Not that much damage done to mine just scratches but the fords front bumper is destroyed. Worrying thing is I had a service with Nissan 2/3 weeks ago and the same garage fitted a new handbrake cable about 1.5 years ago!
Am I in my right to make them pay for both car damages? Taking the car to them tomorrow to inspect
I think you are shaky ground with that, to be honest,
The burden of proof is on you, i.e. they would argue driver error. Unless they have done something on the last service to the handbrake and it documented in the service sheet.
No harm i trying though :shrug:
I think you'll have a battle on your hands getting them to take responsibility, and can't really see why they would even consider it unless they specifically worked on the handbrake recently, but even then....
Glad it wasn't worse damage or injuries though!
I was riding down Clapham High street many years ago when a car pulled away from the kerbside just ahead of me. I carried on and went to overtake without really thinking about it but when the car kept coming out past the white line pushing me further over I turned to have a go at the driver. Hmmm...... no driver !!!
Most of my friends in Scotland are surprised I'm leaving a car on a gear, In my company there is a policy to do not leve vans on a gear just on a handbreak sometimes it's silly because if van is loaded and sits just on handbrake :scare:
In my country when you are learning to drive, instructor is telling you to use 1st gear and a handbrake, do not use just the handbrake.
In my opinion you don't have big chances to win. If they would do handbrake a week ago then yes but after 18 months you could damage it somehow.
It won't be easy to proof it's garage fault...
Good luck
I actually had a very lucky escape the other week. I parked in a carpark, where id parked hundreds of times before. Put the handbrake on the same amount as I always do. Get out and start to walk away and my car starts rolling away towards the back of a landrover.
I have never run so hard in my life as all I could think about was my mint front bumper smashing into the back of the landrovers tow bar and the subsequent repair cost to my car. Luckily I got in the car and managed to stop it in time.
Now I pull the handbrake up higher than id normally do and leave it in gear.
With regards to the OP`s car sitting happily for an hour before deciding to roll off - I have heard of that happening before with other cars - something to do with the disc brakes on the back - as they cool off, they shrink slightly which reduces the pad on disc pressure you first had when you put the handbrake on.
you didnt leave it in gear then. I always do
+1 always
+1
After mine cut my lawn for me, I now always leave it in gear as well :)
I'm sure there was a case a few years ago (on another forum) of a similar thing happening.
And basically what was said was that the driver is responsible for taking all measures practical to ensure his/her vehicle remains stationary.
ie: handbrake and in gear if it's required. Or finding somewhere flatter to park.
Basically, you have no chance of claiming a garage who fitted a cable 18 months ago are at fault. The car will have had an MOT since then, so they could easily claim that some muppet adjusted it or tampered with it or simply knacked it when completely the MOT.
Sorry feller.
The Z uses a drum brake inside the rear disc and it's pretty weak for a car of this weight.
Use 1st gear as it's the one with greatest resistance.
If there's a curb you should also turn your wheels (pointing downhill/uphill):
I was once breaking an S14 out the back of my house, on a slight gradient. We had left the car in gear as the handbrake was rubbish, got it up in the air and started work. A few lads turned up to help, including my brother in his brand new Seat Leon FR, which he parked across the back of the S14 as all the other spaces were taken. :)
Fast forward about 4 hours and weve stripped everything we want, the car is a rolling shell. Dropped it off the jacks and went to light a celebratory ciggy ........ fortunately out of corner of my eye noticed the car was starting to roll down the hill. I literally threw myself throught the open drivers window and grabbed the handbrake, leaving the back of the car about 40mm from the passenger door of the Leon .......... :headhurt:
Moral of the story? Even leaving it in gear wont work if you then proceed to remove the gearbox. :doh:
If the handbrake is not defective then you have no comebacks. If you were to go against Nissan on this you would require an Expert Witness report doing showing that their work or parts were substandard or defective.
It's a very long shot :surrender:
Just wanted to add that I have seen this before in the French Canyons.
We had just parked in the car park for a restaurant and where going inside when we saw a people carrier un-park itself and start rolling towards the restaurant. It was heading straight for where people where sitting outside, but there was a car parked side on infront of them, so it jsut smashed into the side of that!
We decided to eat inside after that :)
