Engine Management Light
scottylad
Hey folks. Story is, was at petrol station turned car on once full of juice and then bam light stays on. checked few things
engine temp is fine
oil pressure is spot on
idle is fine
drives normal
only thing i can think of is. i had berk hfcs fitted with my buddy club pro spec exhaust few months ago but its been fine up untill then.
im from Ayr, Scotland is anyone local that could help me check it out. Cheers
thats worked :). if it was anything serious im sure it will come back on? then get it seen too.
Cheers mate
If its serious, it will flash. If it comes back on, use the guide on here to read the fault code. viewtopic.php?f=35&t=89
It'll probably be catalyst inefficiency code or something similar due to your HFC. If it is, you can buy O2 sensor spacers from Zmanalex to fix it, or get the car Uprev'd to remove the codes and actually tune the car to make the most of your HFC and exhaust.
