alfunko1106 Posted September 3, 2011 Share Posted September 3, 2011 Ive just bought a 350z GT4 2005 (Yesterday!!!) from a dealership and after only having the car for a couple of hours (doing motorway miles and a little urban) Ive found the clutch is slack on the dip and doesn't return.To add to this problem,I'm now finding it nearly impossible to engage/disengage gears.I limped it home and obviously gave the dealership a piece of my mind.Last night Green flag took a quick look and mentioned it may be an internal clutch problem???The technician couldn't even get it into reverse to roll it out to look.Its the next day now and I decided to see if letting it cool down overnight would make a difference and it has.It now feels relatively normal to me.I limped it onto the back of a flatbed truck this morning and its now in a local garage in Manchester (Lockwood and Greenwood) who have a 350 guy back in on Monday.This is my first 350z and im absolutely gutted can anyone help with what it might be and things i should get the garage to look out for because its a joke.cheers guys!!! Al. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 3, 2011 Share Posted September 3, 2011 It will more than likely be a hydraulic issue, so swopping out the slave cyl may fix it. Fresh high temp fluid and a braided clutch line would also be advised. Occasionally the master cyl requires replacing. Worst case scenario is gearbox out for a clutch inspection, however as it is temperature related then I would expect it to be a slave failure. As the car will be under warranty then all required parts should be replaced free of charge, however if you get stuck, just give me a shout as I have ALL the above parts in stock. Alex. Quote Link to comment Share on other sites More sharing options...
alfunko1106 Posted September 3, 2011 Author Share Posted September 3, 2011 Ah cheers Alex Will mention these things to the garage when I get chance on Monday !! Will definitely give you a shout if things don't go to plan. Thanks again for the advice, That has helped out loads!! Quote Link to comment Share on other sites More sharing options...
