coope046a Posted August 31, 2011 Share Posted August 31, 2011 hi guys iv just got a 350z and iv got two big questions. 1st is what could be the cause to my car burning oil and making a lot of smoke when i put my foot down and secound is how do i remove the 112mph limit on the top end? thanks. Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 1, 2011 Share Posted September 1, 2011 hi guys iv just got a 350z and iv got two big questions. 1st is what could be the cause to my car burning oil and making a lot of smoke when i put my foot down and secound is how do i remove the 112mph limit on the top end?thanks. firstly is the smoke black or blue? Back of the bumper oily? Secondly You need either a HKS speed limit defencer or an Uprev. Quote Link to comment Share on other sites More sharing options...
Zugara Posted September 1, 2011 Share Posted September 1, 2011 Get uprev to remove limiter . You have serious engine problems if you are burning oil. Piston rings Valve stem seals Or, it could be unburnt fuel smoke. Good luck. Quote Link to comment Share on other sites More sharing options...
coope046a Posted September 1, 2011 Author Share Posted September 1, 2011 its blue and iv checked the piston presure and they are all the same so i hope its the valve stem seals as i only need to remove the heads. Where can i get these limit removers and how much? can it not be plugged into a computer and taken off? thanks for your help guys. Quote Link to comment Share on other sites More sharing options...
MidnightRacer Posted September 1, 2011 Share Posted September 1, 2011 as far as I understand it. If you have a jap import then a speedo converter will also remove the limit because it tricks the car into thinking its going slower than it is. IE KPH to MPH. I dont also know if putting UK clocks on removes the limit or not. I have UK clocks on mine and its certainly not limited, neither was it with a speedo converter on it. That however isnt to say its either been mapped or has something else hiding somewhere to remove the limit. Quote Link to comment Share on other sites More sharing options...
