slimjim Posted August 27, 2011 Share Posted August 27, 2011 How am I best attaching my MDF rings to my doors for my new Rainbows? I can use the three standard bolt holes but I thought I needed to seal it to (all ready painted the rings with wood-glue solution) to the door. With something like "no-more-nails" or something? Will be covering them with sound deadening of course... just at the back of my mind I think I need to seal them down to the door. Anyone know? Cheers... Quote Link to comment Share on other sites More sharing options...
SteveRS Posted August 27, 2011 Share Posted August 27, 2011 You could try Mitre mate, sticks like Sh*t to a blanket. (try not to get it on you finger) consists of a spray can and a liquid apply the liquid to one side and spray the other, instant chemical reaction. Carpenters at work use it a lot on kitchen cornice and MDF. Quote Link to comment Share on other sites More sharing options...
slimjim Posted August 27, 2011 Author Share Posted August 27, 2011 ooohhh... where do I get it from on a Bank Holiday Sunday/Monday? Quote Link to comment Share on other sites More sharing options...
Keviswatt Posted August 27, 2011 Share Posted August 27, 2011 ooohhh... where do I get it from on a Bank Holiday Sunday/Monday? Mitre mate is the stuff, You can get it at Homebase/B&Q etc. Quote Link to comment Share on other sites More sharing options...
SteveRS Posted August 27, 2011 Share Posted August 27, 2011 ooohhh... where do I get it from on a Bank Holiday Sunday/Monday? Mitre mate is the stuff, You can get it at Homebase/B&Q etc. +1 Yep should be able to get it in either homebase or B&Q. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
Madmarky Posted August 27, 2011 Share Posted August 27, 2011 What you can do to save mucking around with the MDF is take the old speaker and cut the middle out of it and it. Then get some of that sticky back foam strips and line the back of the new speaker surround and attach it to the old housing using some cable ties. I know it sounds a bit Blue Peter ish but trust me the results are brilliant. I first did it as a temporary measure as i was gonna build some door pods but ive had it like it for over 2 years and you would never know. Quote Link to comment Share on other sites More sharing options...
AK350Z Posted August 28, 2011 Share Posted August 28, 2011 Depending on the materials absorbancy, you could use some proper 2 part epoxy like araldite. Will need held in place untill it cures though. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 28, 2011 Share Posted August 28, 2011 Use nails, the longer the better, don't worry if they poke out on the outside, it will help keep chavs away Quote Link to comment Share on other sites More sharing options...
leonk Posted August 28, 2011 Share Posted August 28, 2011 Hi, Mitre Fix is fine for gluing MDF to MDF but if you want to bond MDF to Metal you need something like Sikaflex or a PU mastic adhesive. This will bond it and resist failure due to vibration. Try Tool Station or Screw Fix. We use this stuff at work so am talking from experience regarding how to bond it but you will need an i.c.e. expert to advice you as to whether you need to. Hope this helps a little. Quote Link to comment Share on other sites More sharing options...
