Karlp Posted August 26, 2011 Share Posted August 26, 2011 As above guys looking for a sat nav to mount in a 2004 manual cubby, any price considered PS Can you just splice the usb charger for the sat nav into the HU power cable???? Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 26, 2011 Author Share Posted August 26, 2011 PS anyone fitted a archos tablet into a zed before??? Quote Link to comment Share on other sites More sharing options...
marzman Posted August 26, 2011 Share Posted August 26, 2011 Have you thought about something like this? http://www.ebay.co.uk/itm/New-7-Car-GPS ... 2eb583839f This is basically what a Nurrish sat-nav is... buy it, dismantle it, and fit it into your cubby. Looks a bit scary when you see it mounted behnd your dash with exposed circuitboards etc, but it looks OEM. Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 27, 2011 Author Share Posted August 27, 2011 Wow that's looks pretty smart and cheap! Can you just hardwire these in? And would it fit a 2004 cubby?? Quote Link to comment Share on other sites More sharing options...
marzman Posted August 27, 2011 Share Posted August 27, 2011 It would be a case of completely dismantling it and sticking the screen behind the cubby, and mounting the circuit board behind that. Then you'd need to butcher the power lead and wire that into the +/- of the stereo. 3 hours work if you know what you're doing... (and a roll of double sided tape!) Mine looked like this: Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 27, 2011 Author Share Posted August 27, 2011 Hmm looks quite snare and very oem, do you just need to take the back off the navvy? Or do you need to split the screen from the PCB etc Quote Link to comment Share on other sites More sharing options...
marzman Posted August 27, 2011 Share Posted August 27, 2011 You'll need to remove the PCB and screen from the housing it comes in. Then put double sided tape around the inside of the cubby, and attach the screen to that. Then mount the PCB onto the back of that screen, or make a bracket for it etc... However please be aware - the device in the ebay link i provided - i dont know if thats the right one to use... you should measure the cubby size to see what screen size you need... Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 27, 2011 Author Share Posted August 27, 2011 What size is the one you fitted matey?? Quote Link to comment Share on other sites More sharing options...
marzman Posted August 27, 2011 Share Posted August 27, 2011 Couldnt tell you im afraid... if you search for Nurrish Sat Nav on here - thats what i have. It was already in my car when i bought it, i just ended up removing/refitting it as i broke it - and i never measured it... Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 28, 2011 Author Share Posted August 28, 2011 Thanks marzman Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 28, 2011 Author Share Posted August 28, 2011 Anyone tried fitting one of these; http://www.maplin.co.uk/slate-5-inch-an ... 5&t=module think I would need a 3g one for sat nav use? I think a 7" tablet wouldnt fit the cubby without modding it, Im looking for something that I can stick in a 04 cubby and then splice into the power supply also if you guys have any more recommendations? Quote Link to comment Share on other sites More sharing options...
