Oil drain copper washer
sunshine
Engine sump washer:
Copper crush washer, inside diameter 11mm outside diameter 17mm, 4mm thick before being crushed can be purchased from ebay quite easily, I got 3 for about £2.
Diff and gearbox washers are the same size, nissan part number: 11026-4N200. These are about £2.70 each! Inside diameter 18mm outside diameter 25mm, 1.5mm thick. These are plain washers rather than crush washers and are not copper.
