I've screwed something up...!
evest
Forgive the new thread but I now face a different problem. In a previous thread http://www.350z-uk.com/forum/viewtopic.php?f=27&t=52993&start=0 I was at the stage of having installed my new HU - all working fine - and was trying to wire up a line-booster PC9-460.
The 3amp fuse that the booster came with kept blowing so I decided to put in a 15amp fuse (350z manual says ignition power to the radio goes through a 15 amp fuse), figuring that the worst that could happen would be to ruin the line-booster.
This didn't work and now I have got no power to the HU at all - it won't switch. So I undid the steps taken above, but still no power. I have checked all fuses - box on driver side and two boxes in battery bay - all good. To check that I haven't somehow ruined the new HU, I put the OEM HU back in and still I have no power (it whirs on connection but will not switch on).
I think I've probably gone out of my depth and need to take it to a specialist to sort out, but anybody got any ideas what I have done here?
Cheers :blush:
Yeah I re-grounded it using the wire directly off the HU loom but this didn't help. As the OEM HU is not getting power either I reckon its a problem somewhere else - I'll re-check all fuses since this seems likely problem, but I'm pretty sure they were all ok.
  evest said:
Have re-checked fuses, all are okay but still getting no power to the HU?!
you could have melted one of the power cables by over-rating the fuse and it has then overdrawn on the cable and melted it :shrug:
Well just been out to pick up a curry and have no power to the centre console pods or the speedo/rev etc dimmers. So perhaps its one of the other fuses rather than the radio ones I have checked.
Even though i put an overated fuse in the line-booster - would that not just affect the line-booster itself? Hope I haven't melted a cable - sounds difficult to sort out! Don't have a volt meter but can probably get one from work next week.
Definitley a fuse, Its a 10A (99% sure) in the footwell. I blew the same one installing my headunit :thumbs:
Karl, Ian,
Bang on the money fellas - I've found the blown 10A fuse - it was the mirror fuse which I hadn't thought to check before now. Anyway, power restored, HU working :yahoo: - just gotta tackle the line-booster again - I think if I use a 10A in it this time, I should be ok - will post up some pics when the install is complete.
Thanks for your help on this - very much appreciated, what a top forum!
:thumbs:
Cheers mate - do you remember what fuse you used for the line booster? The 3amp it came with blows every time - but using a 10amp causes the mirror fuse in the dash box to blow. Guess I could try a 5amp and see!
