DaddyCee Posted August 25, 2011 Share Posted August 25, 2011 Just noticed that we the clutch is disengaged that there is a strange whiney noise and it seems to get higher pitched when dipping the gas pedal. Is this normal? All is fine when the clutch is engaged and a gear is selected. Quote Link to comment Share on other sites More sharing options...
Will370z Posted August 25, 2011 Share Posted August 25, 2011 Perfectly normal, common noise you will get used to it. Quote Link to comment Share on other sites More sharing options...
varley16 Posted August 25, 2011 Share Posted August 25, 2011 common on a 350, from what ive read even a new one will do it, without hearing it i couldnt say 100% that its fine, but i think you will find we all or most of us have the same Quote Link to comment Share on other sites More sharing options...
Zugara Posted August 25, 2011 Share Posted August 25, 2011 Noises I fricking hate them, I have one that sounds like a chain being rattled, can't find it for love nor money.... Quote Link to comment Share on other sites More sharing options...
DannyBoy Posted August 25, 2011 Share Posted August 25, 2011 Yep, my clutch makes all the wierd noises you could think off, in fact the whole car is easily the worst i've owned for random unidentifiable noises. on the other hand its the nicest to drive by a country mile, so i guess you can't have it all. DB Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted August 26, 2011 Author Share Posted August 26, 2011 thanks for the advice. such a nice car but such strange noises. Quote Link to comment Share on other sites More sharing options...
evest Posted August 26, 2011 Share Posted August 26, 2011 I had a really deep growling/vibrating noise when at low revs which had me worried - it then developed into a clanging rattling sound - which had me even more worried BUT the car was running perfectly. Still, I was worried about an expensive clutch repair coming my way. Turned out that the insulator panel above the backbox has corroded around the nuts (done 90K+) and was practically hanging off. The low revs were cause the vibration and noise. Couple of quid for some wide washers and five minutes later - sound gone! Quote Link to comment Share on other sites More sharing options...
MK-Ultra Posted August 26, 2011 Share Posted August 26, 2011 I only got my car last week from an offical dealer. And i was getting a strange grinding/wurring noise when my clutch was engaged in neutral and as i pulled away. I took it back to the dealer and they said it was the clutch release bearing so its booked in for next week to have the gearbox out and have the bearing changed. Quote Link to comment Share on other sites More sharing options...
Dom187 Posted August 26, 2011 Share Posted August 26, 2011 I only got my car last week from an offical dealer. And i was getting a strange grinding/wurring noise when my clutch was engaged in neutral and as i pulled away. I took it back to the dealer and they said it was the clutch release bearing so its booked in for next week to have the gearbox out and have the bearing changed. I have just got a 313 from a dealer as well and mine whines abit. If I give the engine a rev when the car is stood still the whine changes with the engine speed. Does that sound the same thing? Quote Link to comment Share on other sites More sharing options...
MK-Ultra Posted August 26, 2011 Share Posted August 26, 2011 I only got my car last week from an offical dealer. And i was getting a strange grinding/wurring noise when my clutch was engaged in neutral and as i pulled away. I took it back to the dealer and they said it was the clutch release bearing so its booked in for next week to have the gearbox out and have the bearing changed. I have just got a 313 from a dealer as well and mine whines abit. If I give the engine a rev when the car is stood still the whine changes with the engine speed. Does that sound the same thing? Mine doesn't really change when i rev it, its just the exhaust and engine tone drown it out. Its more or a grinding noise almost like two stone grinding disks rubbing together. It gets louder after i've been driving to car. It only occurs when the clutch is engaged, be it in neutral or when pulling away. If your not sure just take it back to the dealer like i did while its still under warrenty Quote Link to comment Share on other sites More sharing options...
sunshine Posted August 26, 2011 Share Posted August 26, 2011 I only got my car last week from an offical dealer. And i was getting a strange grinding/wurring noise when my clutch was engaged in neutral and as i pulled away. I took it back to the dealer and they said it was the clutch release bearing so its booked in for next week to have the gearbox out and have the bearing changed. I have just got a 313 from a dealer as well and mine whines abit. If I give the engine a rev when the car is stood still the whine changes with the engine speed. Does that sound the same thing? No because the release bearing is doing nothing untill you press the clutch pedel. If you get a noise whilst its its in neautral and when its in gear that increases pitch with the engine revs you can pretty much gaurentee its the input shaft bearings in the gearbox. I know this because mine makes the same noise and has for as long as ive owned it. Quote Link to comment Share on other sites More sharing options...
