pulleys and belts
balla
Pulley should be fine TBH. My old 350z did near 100k miles with just changing the belts when required. Sometimes the belts need tightening - this would be the first thing to try. However if the belts are cracked then better to just replace them. From what I remember the belts need to be quite tight otherwise they do squeak.
Both of my auxiliary belts are on the way out and its started to sqeal is the a pulley that is prone to going the car has done 64k so its no spring chicken
New Gates belts and low mileage tensioner pulleys in stock. :thumbs:
You usually only have to change the belts, however best to check the pulleys when the belts are off.
Belts here:
viewtopic.php?f=157&t=31548
Alex :)
