Z Stuff - Warning: contains graphic Z content No 2
Protegimus
Nissan 350Z seat back organiser - perfect condition £25.00
very useful, good quality passenger seat back storage with fitting instructions
Nissan 350Z coupe car cover - used, very good condition - sold
fully tailored, lockable protective cover with heat resistance valance at rear
read on...
Protegimus
Boxed genuine nismo Titanium shift knob 128.00 delivered in UK - Deposit taken
Ultimate in nismo shifters adds a touch of class to the cabin; shortens the shift but retains the weight for a positive shift.
Boxed Ti shift knob with fitting instructions, for 5 and 6 speed models, 10 & 12mm fitment. Direct replacement on a UK 350Z, perfect condition.
Protegimus
KinetiX SSV Polished Stainless Steel Manifold
Perfect condition, complete upper & lower plenum replacement kit including instructions and 5mm allen key - deposit taken
This is the SSV, suitable for N/A and also F/I upto ~15PSI. Above this boost level you will need the current SSV Extreme Velocity version, which will set you back $749.00, plus tax, shipping, import duty, VAT and handling fee...
From KinetiX original information, the SSV has matched length intake runners with velocity stacks and the higher volume plenum chamber design equalises air flow between cylinders.
Supplied fitting instructions are text only, a useful guide with images is here
. Fitting is straightforward as long as you take your time, it took me around 2hrs.
In my experience the SSV offers a good performance uplift, especially noticeable in the upper rev range where the stock intake runs out of breath and where the ever popular spacer doesn't help. There is also an impressively flat torque curve (dyno results will follow due to three image limit, but they are already posted elsewhere on the forum). To realise the full potential, I'd definitely recommend an UpRev tune (though again from experience I'd recommend the UpRev for all Z's!) and performance panel filter - I've used both the nismo and HKS filters.
In addition to the pure performance improvement, there is also a good weight reduction from the top of the engine, in the order of 11lbs.
You also get the looks and the sounds.
Protegimus
KinetiX claim less heat soak affecting charge temperature due to all Stainless Steel construction - the manifold does run significantly cooler than the stock intake manifold collector.
Shorter, direct path runners that feed straight into the intake manifold
The KinetiX clears the factory strut brace and has an additional blanked port for boost gauges, etc.
Protegimus
SSV dyno results comparison:
results from another VQ35DE on the same dyno
While not comparing absolute results (runs were on different days and it was +10c hotter on the day of my runs), both the torque curve and HP, especially top end ~6200 onwards, show significant improvements. Both cars have similar mods, intake, SSV/spacer, exhaust and other results also show the same trend.
Above are results from a 2006 Revup engine showing how close the VQ35DE is in terms of HP, while maintaining its superior torque curve.
For anyone interested in F/I, SSV results on a boosted Z can be seen here.
Protegimus
Z-Enterprises five wire Max Ground System in chrome silver £45.00 shipped within mainland UK (USD97.95+ new from Courtesy)
6th grey wire is from Spill, all in good condition with fitting hardware.
Stronger engine starting and improved throttle response, very easily fitted mod.
Fitting instructions included.
Chrome mylar sleeved 4 gauge OFC copper cables
Gold plated terminals for improved conductivity
Full spec's at Z-Enterprises web site.
HKS Super Hybrid panel filter £25.00 shipped within mainland UK (32.95+ new)
VQ35DE 02-06 application
Three layer filter with washable element, has been used for less than 500 miles, so bargain.
Pic's to follow.
Protegimus
