Easy Gearbox Oil Change
DUKE
Hi
This is my 1st message so please be gentle with me.
Got my '03' JDM Z about a month ago with 59k miles clocked, serviced by local nissan dealer since import.
Decided to do a gearbox oil change as no record of a change was on any service receipt, got the Redline combination to mix and give the correct viscosity, after reading about people having to use a small plunger pump to refill gearbox (fill small pump,get under car,pump into filler hole,get out, refill, back under........ I decided that I would mix up the Redline fluids in a 5 litre garden sprayer (£10) remove the spray head and insert the tube in the gearbox then pump the sprayer without being under the car till the fluid started dripping into the drain pan.
Fast, easy, less scars on my back and not so messy.
I may not be the first to do this but if it helps others then GREAT
