Headlight water ingress
ace
I have had my car a year now and this week for some reason I have water on the inside in the n/s Bi-zenon head light I have used the head light washers a few times this week would it be possible that water from this to get inside as I thought the lights were sealed :shrug: can I get inside the lens to wipe it then seal it somehow?
I am not a massive expert on this subject by any means however, as I understand it the unit is pretty much sealed.
First thing is, I suppose, is identifying where the water is getting in. A common cause is useing pressure washers this can get in. Next has the seal where the bulbs goes in, been compromised in anyway?
In the short term I would sugest that you remove the whole head light, remove the bulbs drain out as much standing water as you can, and get a hair dryer on the job!
Whislt its out you can fully inspect the unit.
Good luck
