wheel alignment
kepsyboy
regarding the air con refill, you can buy the gas from halfrauds and connect it to the low end and re gas it, should get about 2-3 refills with 1 tin.
Being an air con engineer I will tell you that you should never need to regas it. If its losing gas then it means there is a leak. If it's leaked then there's a chance the compressor has went. Get an air con specialist to do the work, not qwik fit or a home fix.
But I thought over time, you need to refill your air con gas. I recently refiled my landcruiser after about 15 years.....
