HEADLIGHTS
kepsyboy
hi all , how can i identify if my 2003 import z has hids or standard headlights , i have purchased some replacement lights from jdmhondaparts , unfortunately these only work with non hid models, but will work with aftermarket hids ,but will require mods , jdm say i will need to cut wires before the ballast and adapt them to the wiring or get aftermarket hid kit and adapt , any one got any ideas or links to solve this prob :bang: thanks for reading this post
Turn the lights on while facing a wall. HID's come on dim them get brighter and are a blueish tint. Its hard to explain anymore but it should be blatently obvious!.
and if you DO have HID's replacing them with non HID bulbs is a backwards step IMO. you could always use the bulbs you got in the high beam as these are non HID.
