dhyndi Posted August 19, 2011 Share Posted August 19, 2011 Hello, Just a quick one (I hope) my passenger side window has decided to stop going up and down via either the driver side or passenger side switch. It had worked without fault until the other day. Reading various other posts i suspected the motor was the problem, but when i open and close the door the window still goes up and down as it always would have. Is there a relay or fuse for the passenger window switches?? Quote Link to comment Share on other sites More sharing options...
James B Posted August 19, 2011 Share Posted August 19, 2011 A common problem and one I had. Most likely the contacts on the window motor need cleaning. There's a guide on here so I'd search for that, although I'm sure a helpful member will be able to link it for you. Took me an hour and a hald to do and I'm fairly clueless. Quote Link to comment Share on other sites More sharing options...
Ricey Posted August 19, 2011 Share Posted August 19, 2011 Actually probably much simpler than that. Try the little 'window lock' button next to your drivers side switches...........catches everyone out once! Quote Link to comment Share on other sites More sharing options...
Willy P Posted August 19, 2011 Share Posted August 19, 2011 Actually probably much simpler than that. Try the little 'window lock' button next to your drivers side switches...........catches everyone out once! +1 Caught my sister out the other day. Quote Link to comment Share on other sites More sharing options...
dhyndi Posted August 19, 2011 Author Share Posted August 19, 2011 looks like it was my turn!!!that's it sorted, thanks!!! Quote Link to comment Share on other sites More sharing options...
BatteryLow Posted September 17, 2011 Share Posted September 17, 2011 Actually probably much simpler than that. Try the little 'window lock' button next to your drivers side switches...........catches everyone out once! Haha glad i read this post before taking my door to bits, thanks!! Quote Link to comment Share on other sites More sharing options...
goodatcrashing Posted September 19, 2011 Share Posted September 19, 2011 Embarrassingly, this has happened to me on more than one occasion Quote Link to comment Share on other sites More sharing options...
Chee350 Posted November 1, 2011 Share Posted November 1, 2011 This has just happened to me. This morning the window worked fine. Left work. Won't go down. Driving me crazy!!! Tried the window lock button but no joy. Any ideas? Or is it the clean option above? Quote Link to comment Share on other sites More sharing options...
Siman350z Posted February 12, 2013 Share Posted February 12, 2013 My god......the joy of forums. There I am, Sunday, it's snowing and the passenger side window's jammed- thankfully UP! So I check out the details and find out that the motor is a common problem etc etc...get some quotes and get ready for a £200+ bill (up to £850 for the regulator too?!) or trying to clean it meaning probably most of a day swearing that i've broken the little plastic clips that hold everything together and "oh, where does this last bolt go?" And then I read this and it was the damn Passenger window locking switch which i'd accidentally hit! Why, seriously does that even exist?! Comical. Thank you 350z-uk.com for saving me half my months wage on motors and labour. Quote Link to comment Share on other sites More sharing options...
smudgedon Posted February 12, 2013 Share Posted February 12, 2013 My god......the joy of forums. There I am, Sunday, it's snowing and the passenger side window's jammed- thankfully UP! So I check out the details and find out that the motor is a common problem etc etc...get some quotes and get ready for a £200+ bill (up to £850 for the regulator too?!) or trying to clean it meaning probably most of a day swearing that i've broken the little plastic clips that hold everything together and "oh, where does this last bolt go?" And then I read this and it was the damn Passenger window locking switch which i'd accidentally hit! Why, seriously does that even exist?! Comical. Thank you 350z-uk.com for saving me half my months wage on motors and labour. Purely for comical effect Her - "Hun, the window won't go down" (with the lock on) You - "Yes it will, look" (lock off, put window down, put it back up, lock on) Her - "IT WONT FECKING WORK!!!!" Quote Link to comment Share on other sites More sharing options...
