spursmaddave Posted August 15, 2011 Share Posted August 15, 2011 That's what I meant, the video quality is gonna suck when uploading from the phone while out and about we appreciate the effort honestly we do.... Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 15, 2011 Author Share Posted August 15, 2011 Just for you I did another video, hope the music is to your liking Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 15, 2011 Share Posted August 15, 2011 Video - 10/10 Music 10/10 Knob Control 6/10 Looks good, cant wait to get mine sorted... Quote Link to comment Share on other sites More sharing options...
threefiftyz Posted August 15, 2011 Share Posted August 15, 2011 good work quite tempted to do this myself, just wondering thou .... when you select reverse and the camera comes on - can you still hear the music through the speakers or does that turn off whilst the cameras enagaged? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 15, 2011 Author Share Posted August 15, 2011 In the videos, the music is playing on the HU Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 15, 2011 Share Posted August 15, 2011 Can a reverse camera be fitted to the jap sat nav screen? The jap screen NTSC I believe and can it rum dually with the sat nav itself? Quote Link to comment Share on other sites More sharing options...
threefiftyz Posted August 15, 2011 Share Posted August 15, 2011 In the videos, the music is playing on the HU ...don know why i assumed youd added the sound Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 15, 2011 Author Share Posted August 15, 2011 Can a reverse camera be fitted to the jap sat nav screen? The jap screen NTSC I believe and can it rum dually with the sat nav itself? I know that the jap sat nav can take a reversing cam, cis I saw one in action last night. As to how it is wired up, I have no clue, but I am sure someone on here will know. Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 15, 2011 Share Posted August 15, 2011 Also on flea bay it says hook the camera to the stop light for power?? Surely that should be reverse light for power and then run another cable from reverse light to reverse cam wire on HU for auto switching? Is that correct, feel like I'm confusing myself??! Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 15, 2011 Author Share Posted August 15, 2011 Yes, in essence you can take two powertaps from the reverse light, one to power the cam and one as a signal to tell the screen/HU that reverse is selected and thus auto switching to rear cam view. However I do not know the pin layout for the nissan sat nav screen to know which wire is the signal wire or the connection for the video feed (could be a simple as a plug for vid feed, but not had one out to look at myself) Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 18, 2011 Share Posted August 18, 2011 Right I am contemplating fitting mine tomorrow if the weather is good and I am feeling better.... Sounds simple enough and I am well versed in removing all the necessary trim... So am I right in saying the following - My camera has a small red and a small black wire, the black one is the earth and connect to a bolt as in the pics on the first page. The red is sliced to the solid green wire from the reverse light and also I need to run a wire all the way from the HU )purple connection on the Pioneer) to the same connection of the green wire. Then connect up the video input, make sure it is turned on in the HU and hey presto.... Have I missed anything? What sort of wire do I need to run from the HU to the wire at the reverse light? Quote Link to comment Share on other sites More sharing options...
EH 370z Posted August 18, 2011 Share Posted August 18, 2011 Would this work on the Nissan Connect head unit too? Sorry i dont fully understand how the wires go in to the head unit and mate up. sorry bit of a spaz with wiring Quote Link to comment Share on other sites More sharing options...
slimjim Posted August 18, 2011 Share Posted August 18, 2011 All it uses is 12v power.... and a standard single RCA type lead for video. Can you plug an external video into the standard HU? Quote Link to comment Share on other sites More sharing options...
slimjim Posted August 18, 2011 Share Posted August 18, 2011 Oh ... and dave... anything the same kind of sizes as the green wire you are hacking into will be fine. I used 2.5mm. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 18, 2011 Author Share Posted August 18, 2011 Right I am contemplating fitting mine tomorrow if the weather is good and I am feeling better.... Sounds simple enough and I am well versed in removing all the necessary trim... So am I right in saying the following - My camera has a small red and a small black wire, the black one is the earth and connect to a bolt as in the pics on the first page. The red is sliced to the solid green wire from the reverse light and also I need to run a wire all the way from the HU )purple connection on the Pioneer) to the same connection of the green wire. Then connect up the video input, make sure it is turned on in the HU and hey presto.... Have I missed anything? What sort of wire do I need to run from the HU to the wire at the reverse light? yup. that;s basically it, I used some generic 1.5mm wire to the HU signal and added a female bullet connector to the end (HU side is male of course) Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 19, 2011 Share Posted August 19, 2011 Well I stripped out the boot ok, fitted the camera, ran the cables through the grommet, connected the red wire to the green wire on the passenger side cluster, the black wire to the bolt on the rear (as per slimjims pics) connected the video cable to the back of the pioneer, enabled rear view and nothing.... i get the screen with the warning at the top and a blank screen can't see what I could have wired up wrong, nothing much to mess up is there? Live to the green wire and negative earthed to the bolt, simple or so I though. On the pioneer there are only a couple of options, rear camera enabled yes/no and power earth/battery had it on yes & earth, but tried yes and battery too. Seemed like the camera came on even when I wasn't in reverse Quote Link to comment Share on other sites More sharing options...
R35LEE Posted August 19, 2011 Share Posted August 19, 2011 That looks the nuts Bullet! Far better than drilling the rear towing eye cover Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 19, 2011 Author Share Posted August 19, 2011 Be careful, i had an incedent where i hooked it all up, checked it was working before putting it all bacl, sure enough it did, put everything back and then it didn't work. took everything out the boot again an noticed i had pulled the power off the scotchtap while putting the styrofoam back in. re-done it and all was well. Did you use the green or the pale green wire? it should be the pale green Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 19, 2011 Share Posted August 19, 2011 Be careful, i had an incedent where i hooked it all up, checked it was working before putting it all bacl, sure enough it did, put everything back and then it didn't work.took everything out the boot again an noticed i had pulled the power off the scotchtap while putting the styrofoam back in. re-done it and all was well. Did you use the green or the pale green wire? it should be the pale green Yeah used the pale green wire. Just got a 12v battery from shop round the corner and the camera works fine on my tv, take it down to the car and it doesnt work on the f900bt ? I go into settings and switch reverse camera on and doesnt matter if i select battery or earth i get no picture Just checked the box and it says PAL, maybe i got a wrongly boxed one? I noticed yours had 2 quite thick black wires mine had a thin red & thin black one ? Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 19, 2011 Share Posted August 19, 2011 You might have got a NTSC as on ebay you have to state if you need PAL or NTSC. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 19, 2011 Share Posted August 19, 2011 You might have got a NTSC as on ebay you have to state if you need PAL or NTSC. As i said just above, i did and the box says PAL Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 19, 2011 Share Posted August 19, 2011 Would this work on the Nissan Connect head unit too?Sorry i dont fully understand how the wires go in to the head unit and mate up. sorry bit of a spaz with wiring Chris`I has installed one viewtopic.php?f=103&t=43182&hilit=camera Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 19, 2011 Share Posted August 19, 2011 You might have got a NTSC as on ebay you have to state if you need PAL or NTSC. As i said just above, i did and the box says PAL Oops Sorry dude, you had any joy since? I was gonna get one ordered this weekend too, although could always be a dud one, If no joy I'd email the seller, usually eBay Chinese sellers send a replacement out straight away with my expierence of LED lights and HID sets etc Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 19, 2011 Share Posted August 19, 2011 Nah the camera works fine hooked up to my telly, just nothing when i connect it up to the HU.... Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 19, 2011 Share Posted August 19, 2011 Nah the camera works fine hooked up to my telly, just nothing when i connect it up to the HU.... Hmmmmm Can you try another video source in your HU and see if HU displays it? Quote Link to comment Share on other sites More sharing options...
