balla Posted August 11, 2011 Share Posted August 11, 2011 im picking my z up on friday and it has the full gt pack with the bose system does this mean it has the bluetooth built in. also it has a parrot kit fitted so if it is built in why would it need the parrot ? :S Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 11, 2011 Share Posted August 11, 2011 what age is your Zed. Bluetooth adaptors didnt initially come out with the Zed. It was approx 3 years later. So the parrot may have been fitted before the bluetooth adaptor was available, This later came as standard on new cars but could be purchased for older ones. You would need to check if the zed your getting has got a adaptor. It will be in the arm rest cubby. Some sellers remove them and sell them separately. The bluetooth adaptor is just a module that plugs into the adaptor holder. This part of the kit along with the main control unit which is located under the cubby behind the passenger seat does come as standard install on UK Zeds coupes. Roadsters do not have the phone kit fitted. Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted August 12, 2011 Share Posted August 12, 2011 ah that explains the abscence in mine then, though I did test drive a 350Z (55) plate that had the BT dongle. Quote Link to comment Share on other sites More sharing options...
