Bry Posted August 10, 2011 Share Posted August 10, 2011 just after letting up the clutch in 1st or reverse gear I get a single loud mettallic click from the rear left of the car. After doing a search I'm guessing this could be the rear left CV joint although most posts mention a clicking noise rather than the single click that mine makes. Could anyone confirm my suspicions that it is the CV joint and if it is what are my options for buying a replacement? Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 10, 2011 Share Posted August 10, 2011 May be the cv joint clicky axle issue, or perhaps the pads moving in the rear caliper. Alex Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 10, 2011 Share Posted August 10, 2011 Here you go viewtopic.php?f=157&t=21691 viewtopic.php?f=157&t=21842 Alex. Quote Link to comment Share on other sites More sharing options...
Bry Posted August 10, 2011 Author Share Posted August 10, 2011 Thanks for the reply, I'll see if I can somehow eliminate the pads from the equation and see if the noise is still there. If I do need the Uprated CV kit, do you still have one in stock? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 11, 2011 Share Posted August 11, 2011 Do you only get when you have been parked up say overnight? If so then it may be the parking brake as i know i get this ocassionaly and was worried it was the clicky axle. If it is just one click / clunk it isnt a clicky axle. Quote Link to comment Share on other sites More sharing options...
Bry Posted August 11, 2011 Author Share Posted August 11, 2011 Do you only get when you have been parked up say overnight? If so then it may be the parking brake as i know i get this ocassionaly and was worried it was the clicky axle. If it is just one click / clunk it isnt a clicky axle. No it's fine in the morning. It will make the noise everytime I pull away(about 1 second after letting the clutch up). Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted August 11, 2011 Share Posted August 11, 2011 Ah sounds like it may be the start of a clicky axle then maybe... Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 11, 2011 Share Posted August 11, 2011 I had a similar sympton with my first (2004) ZED when I first got it. Turned out to be a rear pad sticking - supplying garage clearned out both rear calipers and copper greased the shims/back of pads and problem solved. Suggest you check that first, as a whole cheaper fix than the clicky axle repair and I have to say with the axle issue, and having heard several, you usually hear a series of clicks not just one - get someone outside to listen as you move the car back and forth to help identify the actual noise Quote Link to comment Share on other sites More sharing options...
Bry Posted August 11, 2011 Author Share Posted August 11, 2011 Had a mate listen to it last night and he immediately said rear left wheel area and said could be pad moving as it only has a central pin rather than one top and bottom to hold pads.I'll take the pads out tomorrow and copper slip them. Thanks for the tip I had a similar sympton with my first (2004) ZED when I first got it. Turned out to be a rear pad sticking - supplying garage clearned out both rear calipers and copper greased the shims/back of pads and problem solved. Suggest you check that first, as a whole cheaper fix than the clicky axle repair and I have to say with the axle issue, and having heard several, you usually hear a series of clicks not just one - get someone outside to listen as you move the car back and forth to help identify the actual noise Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 11, 2011 Share Posted August 11, 2011 The rear pads, like the front have two pins holding the pads in place, and not one as suggested if you are running Brembo brakes. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 11, 2011 Share Posted August 11, 2011 drop links maybe Quote Link to comment Share on other sites More sharing options...
Bry Posted August 11, 2011 Author Share Posted August 11, 2011 The rear pads, like the front have two pins holding the pads in place, and not one as suggested if you are running Brembo brakes. Yup, I noticed that when I washed the car today I think it's the start of the CV joint going Quote Link to comment Share on other sites More sharing options...
