coldel Posted August 6, 2011 Share Posted August 6, 2011 OK, done the big set of lights, looking good (especially with the new number plate which has domed black letters) but what about the lower ones, think they need doing too now? Are they easy to remove? Although the FlyEyes instructions say to do it with the lights still on the car it was much easier I found off it and I could really wrap the material right around the edge of the light. Anyways, makes the black Zed look much better I think. Quote Link to comment Share on other sites More sharing options...
Lexx Posted August 6, 2011 Share Posted August 6, 2011 IIRC its a full bumper off job to get the indicator clusters out. Bumper removal instructions can be found here: http://www.350z-tech.com/wiki/index.php ... er_Removal Quote Link to comment Share on other sites More sharing options...
coldel Posted August 6, 2011 Author Share Posted August 6, 2011 I grabbed some off cuts and had a go with them in - actually the easy shape and gap between the lights and the bodywork made applying this stuff a doddle. All done - took about ten minutes. Quote Link to comment Share on other sites More sharing options...
TomS Posted August 6, 2011 Share Posted August 6, 2011 Looks good! What size material did you go for? Will be ordering some today! Quote Link to comment Share on other sites More sharing options...
coldel Posted August 6, 2011 Author Share Posted August 6, 2011 I went for two strips of 30x90 The lights are something like 73cm long, so buying the 75cm strip would have been cutting it a bit close, by getting the 90cm stuff it meant more off cuts to do the small lights as well. Quote Link to comment Share on other sites More sharing options...
