Pressure washer not pressuring???!
Karlp
hey guys,
Got my snow foam lance and shampoo through today to find my jcb pressure washer has developers fault the water is going and coming out at the same pressure it's coming out the tap? The pressure washer motor is on but the water is not coming out fast just at normal pressure? Anybody any ideas what could cause this if the pressure washer motor all seems fine??
If the motor is running does it's speed/ noise change when you pull the trigger?
Also have you got a nozzle fitted to the lance? If there is no restriction, it won't come out at high pressure due to the higher flow.
