slimjim Posted August 3, 2011 Share Posted August 3, 2011 Trying to slice into my reversing light positive for my reversing camera WITHOUT taking the bumper off to look at the lights directly. Anyone know which of the 6 crazy colour cables is the one I need to take as a positive? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 3, 2011 Share Posted August 3, 2011 IIRC its green dashed one. Careful not to take it from the main loom (near the wheel arches) as there are two the same Make sure you test it first - its about 2-3yrs since I did mine Its dead easy to remove the passenger brake light (3x 10mm bolts), so best to do that and have a look Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 3, 2011 Share Posted August 3, 2011 Or use this one:- viewtopic.php?f=9&t=39329&p=586502&hilit=steelmate#p586502 5th post down gives wiring colours Quote Link to comment Share on other sites More sharing options...
leonk Posted August 3, 2011 Share Posted August 3, 2011 Just done mine, it's the pale green one. But as stated above please test it. Quote Link to comment Share on other sites More sharing options...
leonk Posted August 3, 2011 Share Posted August 3, 2011 Just to add, I did mine with the bumper off, soldered a wire on and some heat shrink, and then fed the wire back through the gromet into the car. Quote Link to comment Share on other sites More sharing options...
slimjim Posted August 3, 2011 Author Share Posted August 3, 2011 I am trying NOT to have to take off the bumper... Or is it super easy to do? So far I have managed to get everything in and done... and linked up without taking the bumper off. Would be a sod if I have to take it off just for the cable I will try to strip back one of the cables and do a test with an altermeter before I start linking things up. Will try the green dashed one first. Quote Link to comment Share on other sites More sharing options...
