Adam rs Posted August 1, 2011 Share Posted August 1, 2011 Got a bit sucked in with the lovely new double din head units available. After a day of looking around i got sat down and started thinking about why i should change. My standard bose system has no faults and sounds good. What are the benefits of a change and what else do i need for dab aside from the head unit? Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted August 1, 2011 Share Posted August 1, 2011 Some head units are "DAB READY" but only offer the user interface and require a separate DAB unit. A lot of the older JVC models are like this. Newer ones are all in one units. All will most certainly need a new DAB aerial. These can be either be the stick on the inside of the inside of the windscreen ones or external ones (may need drilling ) I went for a single din one with the stick on aerial and find I actually listen to radio a lot more due to the wider selection of stations Quote Link to comment Share on other sites More sharing options...
Lexx Posted August 1, 2011 Share Posted August 1, 2011 If you're happy with the BOSE set-up, spend the money on a re-map. Quote Link to comment Share on other sites More sharing options...
