Karlp Posted August 1, 2011 Author Share Posted August 1, 2011 hope so Quote Link to comment Share on other sites More sharing options...
un1eash Posted August 1, 2011 Share Posted August 1, 2011 Yeh I only have 2 from the ICT lead from sextons, there are another 2 yellow and black but thats for AV These are not for the AV but are the Rear L and R, they are black and yellow so not to confuse them with the fronts, you need to connect these to the rear outputs of your headunit and set the headunit to front/rear not front/sub. Everything is explained clearly in the sticky thead..... viewtopic.php?f=17&t=31260&p=457835 Quote Link to comment Share on other sites More sharing options...
Karlp Posted August 1, 2011 Author Share Posted August 1, 2011 Yeh I only have 2 from the ICT lead from sextons, there are another 2 yellow and black but thats for AV These are not for the AV but are the Rear L and R, they are black and yellow so not to confuse them with the fronts, you need to connect these to the rear outputs of your headunit and set the headunit to front/rear not front/sub. Everything is explained clearly in the sticky thead..... viewtopic.php?f=17&t=31260&p=457835 Okay dude will try Quote Link to comment Share on other sites More sharing options...
