Started the Car Pc on my Zed
rabster
OK so let the fun begin
So i have started on the CAR PC
Spec as follows
Acer Aspire Revo
Carnetix P1900
LIlliput 7" Screen
Logitiec Mini Keyboard/Joypad
Joycon EX
Rear Camera
OBD Reader
C200 Video Camera Input
USB GPS
Onto the fitting the standard housing that comes in the non nav modules doesn't allow enough space to fit a screen in the cubby as you can see below
So i had to order a different unit
once order it was time to get on with the fitting of the screen, no real pics of this as it kinda just fits in and gets glued in place....
but once fitted allows it to look like this
So with the screen in place it was time to modify the computer to work with the PSU
In order for it to work we have to make an additional switch input on the main board
So computer before
Computer with its top off
Locate power switch board this is top left of the computer case
Once removed it looks like this
the contacts themselves are just a standard short to make connection effectively a normally open shorted to normally closed
once connected to i then ran a cable through the case onto a connection on the rear.
that's as far as i got tonight but here are the finished pics today
the screen is being blurred out by my down lighter in the front room doesn't look like this when in natural light
Rabs
IM using a R3700
ITs all installed now but got a slight problem with the audio from the PC im hoping its just a software/hardware problem, its sounding like the board in the pc was being overdriven and to get a good level of sound the radio had to be at 31...... not good lol
but yet if i used my laptop or my iphone the audio sounded great and worked great...
IM using a R3700
good choice on the 3700, pretty powerful for something so small :thumbs:
can't help on the audio front tho.
So here is the new Carnetix loom Made up and measurement made on where to run the cables as with 90% of my work i braided the cables and heat shrunk the ends
Here is the new pc Location
there is a gap under neath here which was ideal to store the PSU and any other ancillary items in
so with that in place time to mount the camera
So onto the checklist
Rear Camera - DOne
Sat Nav -Done
AUX input on headunit - Done
OBD Reader - Outstanding
Fit New screen in cubby hole -Done
Power New screen of same psu as PC - Done
Automatic switching of rear Camera -Done
Sort out poor audio quality - Done
So with the above list 99% completed here is the finished article
NOw the screen
Now for a few videos
The revo has been stuck in Place with strong and thick Velcro to help with vibrations I will be replacing the pc at a later date and upgrade to a SSD drive but the plan is to get everything working finalise all little tweaks then clone the system
Guess I'm not well known enough yet to get lots or response lol
nice one and yes a SSD would be the way forward, very quick boot times as well :thumbs:
Looks good, very similar to the way I did mine a few years ago. HDD will be fine, mine lasted a good few years before I took it out and still going as a desktop PC now.
You need to ditch the crappy Centrafuse nav though. Not sure what is around now, but I was using NavMii. Wasnt the greatest nav but miles better than the Centrafuse nav.
the Reverse camera was fitted without removing the Bumper im very good at getting cables through body panels lolit has only been fitted with a self tapping screw so far but this will be getting adapted to have expanding rubber nuts in there less vibration
The acute angel gives me enough to see the back of the bumper which is all i care about if i can see it in the pic i dont need to go any further back lol
haven't got the OBD working yet as it took me a while on the lexus i had to make some driver setting changes if memory serves so need to track it down again
The centrafuse nav system came with the version i got so using it now lol the old system i built had Navmii as the nav and it did work better and was easier to navigate but the centrafuse fits better with the audio settings and the features for the road like flashing when you approach a round about etc...
  • 1 month later...
