OEM Part Numbers
jamesyj
117204P102 - VQ35DE Alternator/Serpentine Belt - RHD/LHD no difference
11920AG900 - VQ35DE Air Con Belt - RHD/LHD no difference
1520865F00 - VQ35DE Oil Filter
1102601M02 - Washer for said VQ35DE oil filter
For the above, you'll need 4.7l of oil including the filter, 4.4l not including the filter.
110264N200 - VQ35DE Gearbox and differential plug washer. E.g. Same part number for both gearbox and diff.
54618EG02A - RH Anti-Roll Bar Drop Link
54668EG02A - LH Anti-Roll Bar Drop Link
VQ35DE Spark Plugs - These aren't Nissan part numbers, but Google it, as that's what they're known as.
PLFR4A-11 (Hot)
PLFR5A-11 (Standard)
PLFR6A-11 (Cold)
Gap for all - 1.1mm (0.043 in)
54570AC70A - 350z Compression Arm Bush (singular) - The Banana Bar. Note - You can't get this part from Nissan UK.
Popular replacements are Superpro SPF2847K, ZMANALEX also sells the genuine OEM bush. You can also source the OEM part elsewhere, just not from the UK.
dose anyone know where i can get these apart from nissan got a price yesterday they wanted £14 for the four :thumbdown:, searched the net and only places ive found them are in the states, want to swap the oils next week
MuLL
MuLL
Mull,
You do not require to replace the gear box and diff washers.
They are just flat washers and not crush washers and are reusable.
However the crush washer on the engine sump plug should be replaced every time, without fail. :thumbs:
Alex. :)
MuLL
Mull,
Alex. :)
spot on thanks alex :thumbs:
MuLL
Mull,
Alex. :)
This man speaks utter sense!
One note though, £14?!? I've got two on an old invoice @ £2 odd each.
They are just 'washers', nothing special.
