Ruddles Posted July 28, 2011 Share Posted July 28, 2011 I have an advisory after the recent MOT, that both rear anti-roll bar linkages have play in the pin/bush. As I'm brain dead in this department, Is this effectively a simple bush replacement or drop links too? Also would it be worth replacing the sway bar at the same time? That would then lead onto; recommendations for a good kit if possible, eibach, hotchkis, cusco, etc? Any help welcomed! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2011 Share Posted July 28, 2011 I have an advisory after the recent MOT, that both rear anti-roll bar linkages have play in the pin/bush. As I'm brain dead in this department, Is this effectively a simple bush replacement or drop links too? Also would it be worth replacing the sway bar at the same time? That would then lead onto; recommendations for a good kit if possible, eibach, hotchkis, cusco, etc? Any help welcomed! This is what you will require for the anti roll bar linkages. viewtopic.php?f=157&t=48361 Or, viewtopic.php?f=25&t=19378 And, viewtopic.php?f=157&t=42412 All in stock mate, Drop me a pm with any further questions that you may have. Alex. Quote Link to comment Share on other sites More sharing options...
